From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My fix for AirCleaner hold down studs
Over time the OEM air filter studs finally gave it up. And searching for replacements at $25 each became unbearable.
A couple of carriage bolts and viola!
I'd love to have a set of these. PM me with your contact info and cost if you are interested in making me a set.
I just drilled a hole in the original metal tab, and pop riveted them to the shroud.
Nothing wrong with Coach's fix, but more work than I wanted to do.
