Rear Sway bar... Performance difference?
Old Jun 3, 2002 | 03:34 AM
shamvette's Avatar
shamvette
Default Rear Sway bar... Performance difference?
How much of a difference has anyone been able to notice after replacing the factory rear sway bar with a 1 inch high performance sway bar? Is this a mod only serious autocrossers will notice?
Old Jun 3, 2002 | 12:17 PM
John Row's Avatar
John Row
Default Re: Rear Sway bar... Performance difference? (shamvette)
Depending on what your current suspension it could make a substantial difference. What year and what options are on your car now?
Old Jun 3, 2002 | 12:50 PM
vader86's Avatar
vader86
Default Re: Rear Sway bar... Performance difference? (John Row)
could be helpful if you autox alot
Old Jun 3, 2002 | 07:59 PM
shamvette's Avatar
shamvette
I have a 1985 without the Z51 option. I am in the process of changing the factory setup to the following:
1. Edelbrock IAS shocks.
2. Polygraphite bushings all the way around.
3. C5 calipers with appropriate Electro-Dynamics bracket.
4. Baer Eradispeed rotors.
5. Changing D44 3.07 to probably 3.73.
Any other opinions kindly welcome.....
Old Jun 3, 2002 | 08:28 PM
Sharky Guam's Avatar
Sharky Guam
Sounds like you are going autox racing. If so, sway bars are a must. In my opinion, you must balance the front and the rears. Just changing the rears may throw off the handling characteristics of the car. I tried it once in a Camaro and got a worse handling car. We have a Z51 86 vette that rides a little harsh. However, we like it since we often play on the windy roads near our home. Having the right sway bars can really help. FInding a set of shocks that work well with the specific sway bars takes experience. Why did you select the Edelbrocks over a set of Bilsteins? What brand sway bars are you inclined to buy? :cool:
Old Jun 3, 2002 | 10:09 PM
shamvette's Avatar
shamvette
Default Re: Rear Sway bar... Performance difference? (Sharky Guam)
The Bilsteins and what is on the car right now, and I have heard good reports on the Edelbrock shocks. I can also get a pretty good deal on them(friend-of-a-friend type thing).
I ordered my bushing kit through PST and they also have a 'performance' sway bar (1 inch) with the necessary bushings for it. Am I to expect some differences between one companies performance sway bar over another?
You are correct in the autox racing. I live near Sears Point and plan on running there.... but, I will probably only do this 1 to 2 times a year. I will plan on hitting the drag strip at least 1 to 2 times a month.
Old Jun 4, 2002 | 12:47 PM
John Row's Avatar
John Row
You might want to post this question on the forum's racing section. There are some pretty good chasis tuners there.
To Rear Sway bar... Performance difference?
