Coolant Overflow Container Question
I shut off the engine after a 30 mile drive, highway and surface streets, so the engine was up to normal operating temp, checked the level and it was just above the COLD level.
Checked again two hours later and level still the same.
So is this a problem? Both temp gauges read normal temps...no overheating or anything.
The true overflow tank is an add on item used with a conventional cooling system. The conventional cooling system uses a radiator, which has an attached filler neck to which a pressure cap is attached. The system is filled though the filler neck on the radiator and should be filled to about ½” to 1” below the bottom of the filler neck. If the system is filled any higher, it will be over full and the excess coolant will be vented from the system. This happens when the heat builds up within the coolant, it expands, increasing the system pressure above the pressure holding capability of the pressure cap (listed on the cap in pounds per square inch or PSI) causing the excess coolant to be vented out through the overflow vent which is exposed when the cap sealing plate is forced upwards. The excess coolant is then vented to either the atmosphere or into an overflow tank, which functions as a catchment basin. The overflow tank is under atmospheric pressure while the cooling system is under atmospheric pressure plus the pressure generated by the heat expansion of the cooling medium. As the cooling system begins to cool down, the internal system pressure drops until it allows the pressure cap spring to overcome the system pressure and the cap then forms a seal again on the bottom of the filler neck. This takes place when the internal system pressure drops to lower than the rated pressure of the radiator pressure cap. Thus, the cooling system pressure will always be above the atmospheric pressure of the overflow tank until the pressure cap again seals and the entire system is completely cool. At that time, both the cooling system and the overflow tank will be at atmospheric pressure. As can be easily seen, the flow of excess cooling can be in one direction only—out of the cooling system and into the overflow tank. The coolant in the overflow tank cannot flow back into the cooling system because a liquid cannot flow from a lower pressure to a higher pressure. Thus, an overflow tank serves strictly as a catchment basin, not as some for of extra coolant reservoir.
Thanks for pointing-out the facts.
joe
joe
Why else would your overflow bottle be marked "Hot" and "Cold"? Description might be right for a 1950 car, but not for the new hi-tech cooling systems. Sorry to disagree.
I removed the pressure cap and I do not see how coolant could be drawn from the overflow container back into the system......please explain more.
Also, if everything is working properly, the radiator will be completely full at all times. This minimizes the amount of air (oxygen) that is absorbed by the radiator fluid, which minimizes corrosion in the cooling system. If your cooling system isn't staying full at all times, you have a vacuum leak somewhere.
I shouldn't have to say this, but don't remove your radiator cap when the engine is hot. The pressure cap may be preventing the coolant from boiling, but if you remove the cap, the entire amount of coolant in your system may suddenly boil, creating a dangerous guyser!
What is going on?
Thanks in advance!
