"84" wiper switch & mirror problems
Old Sep 26, 2012 | 07:35 PM
garryowen's Avatar
garryowen
Default "84" wiper switch & mirror problems
wiper switch is bad and can't find a replacement.
looking for a replacement or work around that will fit with a little modification.
thinking maybe one from a dash mount slid switch form a "73" GM pick up.
second problem; the plastic tabs, that hold the glass side of the out side mirror metal cross are broken. both side mirrors are flopping around.
any one know of a place that sell the mirror glass with the backing plate attached and will snap on?
Old Sep 27, 2012 | 03:01 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You might try Vette2Vette for quality used parts.
MAM has the outside mirror trunion: '84-96: #606-315, $6.99
Old Sep 27, 2012 | 10:13 AM
fredd1's Avatar
fredd1
The wiper on my '84 wasn't working so I got a salvaged switch to replace what I thought was the problem but it turns out the circuit board on the wiper motor was bad, not the switch (paid $50 for the switch and then another $100 for a rebuilt wiper motor with a working CB -ouch!).
Old Sep 27, 2012 | 10:34 AM
garryowen's Avatar
garryowen
thanks guys
sure the switch is bad. tested with a vo meter. when on off position, has continuity to motor and wont shut off. you have to move to top of switch and wiggle to get to shut off.
wipers stay on most of the time.
checked with switch unplugged. jumper wired plug and works fine. not to handy with no switch and a jumper wire hanging out of door
will try vette 2 vette.
thanks
Old Sep 27, 2012 | 10:39 AM
garryowen's Avatar
garryowen
my trunion cross is ok. its the plastic on the back of the glass that it snaps into thats broken
Old Sep 27, 2012 | 12:32 PM
65Z01's Avatar
65Z01
In that case I suggest you contact Vette2Vette for a good used mirror as well.
Old Sep 27, 2012 | 12:51 PM
garryowen's Avatar
garryowen
thats my next step
and hoping they might have a wiper switch as well.
thanks for contact
To "84" wiper switch & mirror problems
