4+3 help
Old Sep 28, 2012 | 01:17 PM
Boboridesthefa's Avatar
Boboridesthefa
Default 4+3 help
Im putting a trans in my car I want to change the fluid befor it goes in I got a new filter and gasket but I'm unsure what type of fluids go into the od unit and fluids for the 4 speed and the amount I will need thanks for your help
Old Sep 28, 2012 | 04:31 PM
77-85's Avatar
77-85
Navigator
OD unit uses Dexron III and the main case uses standard 80W-90 gear oil. I can't recall exactly how much fluid is required, but I think that the OD unit needs just under 1 QT of fluid, and the main case needs just under 2 QTs of gear oil.
Old Sep 28, 2012 | 04:38 PM
Boboridesthefa
Does any one have ant spific oil they use for smoother shifting ?
To 4+3 help
