DTC 1441 Code and Replacement Parts
I have a 1996 CE LT1 that is throwing the DTC 1441 code. I have replaced the EVAP Canister Purge Solenoid Valve and am still getting the code. Ordered a new EVAP Purge Switch after noticing the tank was holding pressure (mechanic recommendation). The new switch from ebay (PN 1255984) is different than the switch on the car (PN12554025). The difference appars that the OEM lacks an extra elbow at the electrical switch connector.
[IMG]E:\[/IMG]
My questions are:
Has anyone recently fought this battle? Any advise would greatly be appreciated.
Has anyone been able to find the correct EVAP Purge Switch PN12554025? My ebay and other searches have only come up with PN12555984, which appears to need an additional hookup..
Or, is the extra elbow on the new switch a vent line? Appears to be a tapered plastic hose. I get the feeling I may be wrong on this one.
Thanks in advance for the help.
