Steering Rack
Old Oct 2, 2012 | 08:10 AM
Sharrell's Avatar
Sharrell
Default Steering Rack
I guess it is true what they say about old Corvettes. Noticed fluid leak on garage floor and found it to be leaking from the steering rack. Anyone had an issue with leaking steering racks? What did you do to fix the problem?
Old Oct 2, 2012 | 08:17 AM
Aardwolf's Avatar
Aardwolf
Had one with a leak awhile back, replaced the o-ring on the hard line and all was well.
Old Oct 2, 2012 | 08:31 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
If you have to replace/rebuild the rack I highly recommend Turn One.
Old Oct 2, 2012 | 09:51 AM
oldalaskaman's Avatar
oldalaskaman
lucas oil makes a rack and pinion liquid seal rejuvenator, it works great , used it for years in alaska on everything from volvo's to chevy's, saves big time on parts replacement, napa and others sell it
Old Oct 2, 2012 | 11:21 AM
WW7's Avatar
WW7
I agree with the above..If it needs to be repaired , send it here....WW
http://www.turnone-steering.com/
Old Oct 3, 2012 | 01:01 AM
mcm95403's Avatar
mcm95403
Might as well get a Z51 quick ratio rack while you're in there. Only 2 turns lock to lock.
To Steering Rack
