stutters & won't pull
Old Oct 5, 2012 | 09:33 AM
gunnerjuju's Avatar
gunnerjuju
Default stutters & won't pull
symptoms = idles fine in park but under load & wot it stutters and doesn't pull until about 3000 rpm. Fuel economy has dropped by half. no codes etc
fuel pressure @ 36-40 during idle and it holds after shutdown. going to replace the fuel filter tonight although I don't think it is a filter issue due to good pressure during idle. I suspect ignition bc of previous problems with spark plug wires.
any suggestions on what I should check would be appreciated
stock 1989 Auto
Old Oct 5, 2012 | 09:42 AM
bjankuski's Avatar
bjankuski
Check your cap and rotor. It could also be an injector problem. Start by eliminating the cap and rotor.
Old Oct 5, 2012 | 10:17 AM
383vett's Avatar
383vett
I always start with cap, rotor, plugs and wires.
Old Oct 5, 2012 | 10:52 AM
cv67's Avatar
cv67
St. Jude Donor '05
Sounds like a couple of women Ive known
Old Oct 5, 2012 | 11:04 AM
wdsj's Avatar
wdsj
lol
Old Oct 5, 2012 | 11:10 AM
gunnerjuju's Avatar
gunnerjuju
I'll change those out also. I have a rotor laying around and then I'll check the plugs and wires...
gunnerjuju's Avatar
gunnerjuju
Old Oct 5, 2012 | 11:22 AM
Deepa's Avatar
Deepa
Any way I can help? Did you ohm out the injectors?
I would also check out the TPS too. Did you ever get datamaster to read/operate correctly?
This would show you if theres a flat/broken range for the tps.
Let me know if I can help.
Mike
Old Oct 5, 2012 | 02:33 PM
gunnerjuju's Avatar
gunnerjuju
Mike
Mike I'd appreciate any help you could offer. I haven't been able to get my laptop to datalog.
I recently ohmed out the injectors cold they were all 16.4 and hot they were #1=17.2 , #2 thru # 6=16.9 #7=17.1 #8 17.3.. I'll recheck them and the TPS when I get home tonight. If fuel related I just don't understand why fuel economy has suffered so much.
Old Oct 5, 2012 | 03:30 PM
Deepa's Avatar
Deepa
I'm pretty busy this weekend but i'm open monday after like 2 if you want me to take a ride up with my laptop/cable/etc and anything else that may help and we can give it a go...
I'll bring my vette so we can steal parts to see if it helps.
Mike
Old Oct 5, 2012 | 03:58 PM
gunnerjuju's Avatar
gunnerjuju
Mike
Thank you Mike, I'll have beers chilled
Old Oct 5, 2012 | 10:55 PM
Deepa's Avatar
Deepa
Let me know what I need to bring, as I do not know what you have available at your place.
Thanks,
Mike
Old Oct 5, 2012 | 11:59 PM
leesvet's Avatar
leesvet
CATS .............................meoooowwwww wwwwwwwwwwwwww SPLATTTTTT huh...
Check for a plugged up CAT..Caused power to flatten out. Gutless, EGR Valve too. it allto text inj ts
Old Oct 7, 2012 | 09:55 AM
gunnerjuju's Avatar
gunnerjuju
I replaced the fuel filter, fp,sock, rotor & gapped the plugs. Plugs #4&6 appeared hot. Run much better now. Seems to hang in 2nd gear way to long but friend recommended I changed tranny fluid. Couldn't check exhaust because I can't get a gauge on the o2 sensor or air pipes ( I don't have the right fittings). I am still concerned about the drop in fuel economy.
Old Oct 7, 2012 | 09:58 AM
gunnerjuju's Avatar
gunnerjuju
Mike it's running better now but I'd appreciate if you could help me check the timing & data log to see what's going on. I don't have a timing light
Old Oct 8, 2012 | 06:44 PM
90vett's Avatar
90vett
Check the fuel injectors!
Old Oct 8, 2012 | 08:56 PM
gunnerjuju's Avatar
gunnerjuju
I took it out to Mike/Deepa and he checked the timing. It was way off 0 instead of 6. We set it to 8 and wow what a difference. drives better and MPG is way better. Thanks for the assist Mike
To stutters & won't pull
