ZZX Cam
Old Oct 5, 2012 | 11:49 AM
Vincentiroc's Avatar
Vincentiroc
Default ZZX Cam
Has anyone been using this lately? If so what size engine and performance gain did you see.
Old Oct 5, 2012 | 01:56 PM
856SPEED's Avatar
856SPEED
well, I run their ZZ9 roller which is not near as big, but from what their catalog states someone runs this cam (the ZZ-X) with their miniram on a 350 and ran 127mph @ 11.15 in the quarter....looks like the dyno was 4.65.1 crank horse power @ 6500 rpm and 411 foot pounds at the crank (engine dyno) at 5250/5500 rpm.....must be a decent cam..
looks like 290 during on intake/exhaust with a .558 gross lift on both sides/112 lobe sep.
nice cam
Old Oct 5, 2012 | 01:57 PM
cv67's Avatar
cv67
St. Jude Donor '05
Must have been spraying it hard.
Old Oct 5, 2012 | 03:04 PM
Vincentiroc
127mph is a hell of a lot of trap speed on a 350. I wonder what gear and heads were used.
Old Oct 5, 2012 | 04:14 PM
bjankuski's Avatar
bjankuski
I run the cam on a 406 and it peaks at 6250 RPM on my combination. You can check my sig for all the data.
In general it works well, is there better, maybe but it will perform.
Old Oct 6, 2012 | 11:39 AM
856SPEED's Avatar
856SPEED
seems like a lofty number for a 350; they advertise that in their catolog which means nothing w/o knowing all of the facts; yes, it could have been sprayed or whatever.....127 mph is laying it down pretty hard in the 1/4!
it looks like it does have a long duration and probably makes power on the upper end of the RPM scale making it more suitable for a miniram intake...but I know if I installed that cam in my car even with the AFR/TPIS heads (187cc) and miniram I run, I don't think I will get 127mph in the quarter even with a new tune to accomodate it.....as a matter of fact, I know I wouldn't.
I like their parts, though! I will go on record to say I am a TPIS supporter b/c if not for them us C4 builders may have to abanden the hobby and go to C5/6 cars.....or something else....they do some neat stuff there!
Old Oct 6, 2012 | 11:41 AM
cv67's Avatar
cv67
St. Jude Donor '05
No way 127 was NA 350 with that cam esp with 465 at the crank LOL sorry!
Old Oct 6, 2012 | 03:21 PM
88BlackZ-51's Avatar
88BlackZ-51
127 mph in a C4 is north of 450rwhp......
comp cams have newer lobes.....i could look into a custom cam.
infact 127-128 is what i am hoping for and i have alot more cubes then three hundred and fifty!
Old Oct 11, 2012 | 07:33 AM
C4in mesa's Avatar
C4in mesa
I am pulling my 1988 L98 out next weekend then dropping it off to Baileys Machine. I am leaning towards the ZZ9 cam but am not certain it is the right choice ? I have SLP runners, gasket matched ported. Gasket match ported stock intake manifold which I'm told by some is a waste of time ? And the same ported plenum. Stock TB as I have been told no need to go any bigger. Having a roller rocker kit put in. Hypertech power coil from Summit. 24lb Bosch injectors. J.E.T. can't sell me a chip without the cam specs so need to decide soon. Long tube headers and Flowmaster hi flow cat and mufflers. I just want it all to WORK ! I fear the chip won't work and I will need a Dyno tune ? A shop here in Phoenix told me minimum $1,200. God I hope the chip works ! My reason for changing the cam is for HP gain. 30-40HP gain would be great. I also am putting a undersize pulley kit on the engine. I am hoping all this stuff put together will give me 300-330HP at the crank. A top speed of 165-75 max RPM 5,500 is my goal. This is a street car not a track car. The headers are emissions ready from Summit. I am so close to just going back with the stock cam to avoid the $1,200 tune and live with the other changes to boost my HP.
Old Oct 11, 2012 | 09:34 AM
cv67's Avatar
cv67
St. Jude Donor '05
Forget the Jet chip and the 1200$ tune
Call Wongs performance in portland he will take care of you and get you going (TJ Wong). Guys here can help teach you how to datalog to have him touch up the tune if need be.
Port matching maybe better than nothing if you can do it yourself. To pay someone, no. Fully ported top to bottom worth it depending on your wallet/expectations
Old Oct 11, 2012 | 08:32 PM
l98tpi's Avatar
l98tpi
Max G’s
I have the zz409 and am completely satisfied. The only draw back is hard to start and idle cold. It gets better once it warms up. I did know this would be an issue before I installed the cam. I'm sure the zzX would be even rougher to keep and start at idle. If you are driving your car on the street or use it for cruising, I would not use either of these aggressive cams. I would go with the ZZ9 for street use.
Old Oct 11, 2012 | 08:50 PM
Vincentiroc
I was running the 280XFI. It was tune to idle just fine and starts up just fine as well. You need to give it a better for those areas.
Old Oct 11, 2012 | 08:56 PM
Mike 92LX's Avatar
Mike 92LX
ZZ9 is fine for your mods. I agree no jet chip needed. Your combo looks good. Make sure you get harden pushrods and guide plates too along with match valve springs
Go here if you can't find someone local to get you a prom
http://www.fasterproms.net/
Old Oct 11, 2012 | 10:01 PM
383vett's Avatar
383vett
127 mph is what I trap with a 406 and 12.5 compression. I wonder what compression and what heads the test motor was running.
Old Oct 12, 2012 | 10:31 AM
Vic'89's Avatar
Vic'89
I'd like to know more also.
BTW, my stock bottom end 350 with a ZZ9 has run 120 MPH.
Vic
Old Oct 12, 2012 | 12:03 PM
Vincentiroc
Vic
What mods do you have to go 120mph?
Old Oct 12, 2012 | 12:17 PM
cv67's Avatar
cv67
St. Jude Donor '05
Oh a few
To ZZX Cam
Old Oct 12, 2012 | 12:58 PM
ch@0s's Avatar
ch@0s
Old Oct 12, 2012 | 01:51 PM
Vincentiroc
Well my plans is to build a 396ci with fully ported Trick Flow 23*, ported 1205 Miniram and ZZX Cam in a 1990 IROC 5speed with 3.73 gears.
Old Oct 12, 2012 | 11:02 PM
l98tpi's Avatar
l98tpi
Max G’s
Cam Lobe Separation Angle cannot be tuned out. It's the nature of the beast. I had my car dyno tuned to get everything to run as efficient as possible.
LOBE SEPARATION ANGLE: This is the relationship between the centerlines of the intake and exhaust lobes. A 110-degree lobe separation angle means that the peak opening points of the intake and exhaust lobes are 110 degrees apart. This is ground into the cam and can't be changed without changing cams. Lobe separation angle is another way of expressing overlap, which is the term formerly used by cam manufacturers. Overlap is the amount of time that both valves are open in the same cylinder. When both valves are open at the same time, cylinder pressure drops. A cam with 106 degrees of lobe separation angle will have more overlap and a rougher idle than one with 112 degrees, but it'll usually make more midrange power.
Read more: http://www.hotrod.com/techarticles/1...#ixzz29918l5lU
