headlight motor
Old Jun 4, 2002 | 08:57 AM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default headlight motor
my right headlight seldom works.I took it apart and the bushings were ok but changed the gear and bushings anyway.I suspect the motor has dead spots which is why the motor seldom worksWhere is best place to get replacement motor and how much they going for?
I just recently bought this 89 vert and I sure do like it.
Old Jun 4, 2002 | 03:26 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: headlight motor (all smiles 81)
Call Jeff, 18carfan.
Old Jun 4, 2002 | 10:50 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
I would try to rebuild the motor before I bought one, The motors are very exspensive. I am sure an alternator shop may want to try to rebuild it for you.
Old Jun 5, 2002 | 08:40 AM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
I ordered the motor rebuild kit today so hopefully that will fix it.
Old Jun 5, 2002 | 12:33 PM
VQT88Vette's Avatar
VQT88Vette
Where did you order the rebuild kit at? What does it consist of? I know about the replacement gear but didn't know about the rebuild kit.
Thanks,
Old Jun 5, 2002 | 02:36 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: headlight motor (VQT88Vette)
coming from zip products.It doesn't say what it consists of.I think it will be brushes anyway.the kit was only $11.40 plus freight.I should have it in a few days.I'll let you know then.
To headlight motor
