optispark question
Old Oct 7, 2012 | 09:41 PM
Pingman326's Avatar
Pingman326
Default optispark question
I just purchased my first corvette, 1993 in decent condition. The first thing I noticed was the car was running hot and the coolant looked like rusty water. I decided to flush the system and replace the thermostat. Needless to say I ruined my optispark from what I've been learning. So now I'm going to replace it along with the water pump as everyone recommends. My question is, how do I keep this thing from getting wet again? Just opening the air bleed on my thermostat housing could leak down on it! What about water puddles on rainy days?? It seems like a poor design if it's that sensitive. Is there anything I can do to protect the new one ?
Thanks!
Steve
Old Oct 7, 2012 | 09:55 PM
SJW's Avatar
SJW
Pack rags under the bleeders before you open them. Some folks have added a drain hose to the weep hole under their water pumps, to try to keep leaking coolant from getting onto the Opti. I've never heard of an Opti getting drenched by driving on rainy days.
Consider an aftermarket Opti that is actively vented, as opposed to the passively-vented OEM unit, as a replacement.
Live well,
SJW
Old Oct 7, 2012 | 09:56 PM
mixalive's Avatar
mixalive
Dude... DO NOT USE CHEMICAL FLUSH PRODUCTS...... You will be very sorry..
Old Oct 7, 2012 | 10:09 PM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
Drainage - disconnect the lower radiator hose from the engine block first. That will drain both the radiator and a portion of the lower block. Once drained - loosen (but do not remove) the waterpump bolts then tap the housing loose. - allowing a small trickle.
The Delco pump I received already came with thermostat and waterneck already installed.
Not sure what comes with reman/aftermarket tho.
Opti-spark - Go with a quality replacement. May seem to be expensive in the beginning; but buying a cheaper alternative will come back and be short-lived causing to replace it again prematurely. Would not want to do this job twice.
Petris Enterprise offers an upgraded quality component - which is already on my short list.
http://petrisenterprises.com/index.p...d=20&Itemid=26
Old Oct 7, 2012 | 11:04 PM
chrldo's Avatar
chrldo
CHECK THIS OUT : www.corvette fever.com/howto/16758/ This is what i did to my 92. ( there is no space between corvette and fever)
Old Oct 7, 2012 | 11:42 PM
Drew1Down's Avatar
Drew1Down
i have 6k on my petris opti, so far so good. do the front seals when you do your opti for the first time.
Old Oct 8, 2012 | 09:05 AM
Pingman326's Avatar
Pingman326
Could you give me that link again ? This one didn't work.
Old Oct 8, 2012 | 09:08 AM
Pingman326's Avatar
Pingman326
Which seals should I replace ? I saw one for the opitspark shaft, is that one of them ?
I'm still waiting on shop manuals that I ordered to show up.
Thanks,
Steve
Old Oct 8, 2012 | 02:00 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Try this link:
http://www.corvettefever.com/howto/16758/
Old Oct 8, 2012 | 02:36 PM
96GS#007's Avatar
96GS#007
There are no radiator hoses that run to the block. They both go to the water pump, as do the heater hoses....
If you want to drain the block, you pull the knock sensors.
The reman water pumps come both ways...with or without the water neck and thermostat, so be sure to check when ordering.
Old Oct 8, 2012 | 03:04 PM
mixalive's Avatar
mixalive
The waterpump drive seal is very tricky. Requires a special installation tool. Check out these links. One has an alternative to the special tool.
http://www.youtube.com/watch?v=OjIT_FT-mDI
http://www.youtube.com/watch?v=lOGRMVLrEhE
Old Oct 8, 2012 | 03:38 PM
96GS#007's Avatar
96GS#007
Originally Posted by mixalive
That be an awesome looking engine, James Bond..
500+ hp at the crank. The ol' Grand Sport needed some power to live up to expectations associated with having stripes
Old Oct 10, 2012 | 01:23 PM
radar502's Avatar
radar502
This is what I do ..Had a 95 LT-1 run with the fount of the motor under water never went dead had to turn it off ,was blowing rater out the pipes like a pump.. How I do that first buy GM OPIT not cheep junk and open it up and use some very good sealer around the thing put it back togeather also seal the wires with water prof sealer and seal the the opit harness hole ,,then let your wife drive it in a ditch with 5 ft of water one block from your house . Water was over the fount of the motor and still running..Keep water out they will run...I was a good vet... Got to be smarter that what your working with..
Old Oct 10, 2012 | 02:39 PM
RUU's Avatar
RUU
A Grand Sport.. Come on Dude.. That engine deserves a Vette..
I hope you put a frame under that Grand Sport to handle that horsepower..
Old Oct 10, 2012 | 03:46 PM
96GS#007's Avatar
96GS#007
I'd make a comment, but you can't fix stupid. Run along and troll somewhere else.
Old Oct 10, 2012 | 04:06 PM
Bandit's C4
If you won't... I will.
Guess what frame is used for the LT5 or the Callaway twin turbo?
Old Oct 10, 2012 | 05:51 PM
desertmike1's Avatar
desertmike1
To optispark question
Old Oct 11, 2012 | 01:50 AM
Phat98's Avatar
Phat98
Seriously???
Old Oct 13, 2012 | 02:42 AM
Phat98's Avatar
Phat98
Honestly... I originally misread the post and mistakenly thought 007 meant a Grand National. Which hardly has a frame at all..
So the troll stands corrected.
Try again....
Old Oct 13, 2012 | 11:00 AM
chrldo's Avatar
chrldo
C'MON GUYS LIGHTEN UP! this forum is for helping each other not putting people down.
