By-pass trick question
Old Oct 7, 2012 | 09:45 PM
Zorro O's Avatar
Zorro O
Default By-pass trick question
I am trying to figure out where each hose comes from and goes to, for the throttle body by-pass. I have a 86 engine with TPI in my 79 C3. On the front of the TPI, on the bottom of the throttle body is a hose that loops from the TB to the intake manifold. As near as I can tell I am supposed to remove this hose and run one of the heater hoses to it's fitting, the looped hose's lower fitting on the manifold. Is this right? And if so which heater hose? Does it matter which heater hose goes to the intake and which one goes to the water pump? Wow that's clear as mud.
Is this the fitting?
Zorro
Old Oct 7, 2012 | 10:09 PM
383vett's Avatar
383vett
The throttle body has one water hose going in and one going out. Disconnect these two and use a pipe to connect the two rubber hoses to bypass the throttle body.
Old Oct 8, 2012 | 12:36 AM
lt4obsesses's Avatar
lt4obsesses
Not even worth messing with.
Old Oct 8, 2012 | 01:45 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I just did this mod and the main reason was to avoid the coolant drain every time I want to remove the TB...
On my prior '88 I bought a "U" shaped hose, ran it from intake base back behind the A/C compressor to hide the splice into heater hose.
On this '88 I just cut back the OEM hose from the intake base, ran the heater hose under the AIR pump hoses and did the splice behind/below the AIR pump; it was damn cramped but now still have the OEM heater hose with no visible splice unless I remove the TB.
And, yes, that rusty-ended fitting looks like the one to which you need connect the heater hose.
BTW, I use black rubber nipples over the old in/out ports on the TB to dress up those now unused coolant ports.
Old Oct 8, 2012 | 03:11 AM
Zorro O's Avatar
Zorro O
What got me started on this, was swapping TBs three times in the last month. Resetting the TPS, IAC and TV cable was bad enough without dealing with the coolent. Thanks for the conformation on the rusty fitting. That gives me a place to start.
Zorro
Old Oct 8, 2012 | 07:45 AM
TA's Avatar
TA
For this reason alone it was well worth it. When I did mine I didn't use any connectors. I got one piece of heater hose that was long enough to go straight from the heater core to the intake manifold.
Old Oct 8, 2012 | 10:43 AM
mcm95403's Avatar
mcm95403
http://forums.corvetteforum.com/c4-g...completed.html
Old Oct 10, 2012 | 03:55 PM
Zorro O's Avatar
Zorro O
Thanks for the tip. That hose, worked great.
Zorro.
Old Oct 10, 2012 | 07:24 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
The bypass on mine is done the same way with one solid hose. Joining the two hoses with a splice section leaves too much possibility for leakage.
Old Oct 10, 2012 | 10:28 PM
mcm95403's Avatar
mcm95403
Zorro.
This is exactly why I like to document everything I do on this site. Makes it easy to help others later down the road.
To By-pass trick question
