Ok, Will a C4 safely pull a small boat trailer
Old Jun 5, 2002 | 02:22 PM
91mongoose's Avatar
91mongoose
Default Re: Ok, Will a C4 safely pull a small boat trailer (John Row)
How far into the water do you want to back your Vette to launch and recover your boat?
If that becomes a problem you can get the tongue lengthened on the trailer. I did that with my jetski trailer after the water level at the lake dropped to the point where I was getting the wheels in the water.
Old Jun 5, 2002 | 04:33 PM
CptMorgan's Avatar
CptMorgan
Wow, what a great response...
Here's the reason why I'm even entertaining the idea of using the vette as a "Mule". I've got a late 70's, 18ft Ski/Fish boat that weighs 3500+ lbs. I've been towing it around with my father's F150 (good little truck for a heavy-butt boat). But, last week I came home from work and found a 2002 SVT Lightning parked in the carport and no more old F150. Until my father gets over the “New Toy” phase (about 4 to 6 months for a new vehicle) no one else in the family will be able to use it. So he suggests that I sell my boat and go halfers on a new 15ft Sport Boat that we can share and I can tow without touching his new Truck.
I don’t have an owners manual for my 87, does anyone know if the car is actually rated to tow anything?
Old Jun 5, 2002 | 04:37 PM
rideklein's Avatar
rideklein
Default Re: Ok, Will a C4 safely pull a small boat trailer (CptMorgan)
I've seen it done. This guy was pulling a big 'ol ski boat.
Why not?
Old Jun 5, 2002 | 08:12 PM
91mongoose's Avatar
91mongoose
The owners manual suggests that you don't tow with it. But if it really caused problems, do you think reese and the others would risk making a hitch for it? If you think about what you want for towing smaller loads the vette has it:
* It's kind of heavy
* It has good brakes
* It has lots of HP / Torque
Like I said, I never had any problems towing with mine other than keeping the trailer on the ground :)
Old Jun 6, 2002 | 12:31 PM
NavyVet's Avatar
NavyVet
I pull a small trailer with race tires & tools. It weighs about 400 pounds total and has a tongue weight of 85 pounds. I've never had a problem. I must have built it right too, because my trailer is faster than most cars :D
I don't think anything much heavier is realistic. It's not an issue of torque & power, but more an issue of what the springs, shocks, etc. are rated for. The Vette doesn't have that much total weight carying capability in its design. Figure your weight, passenger, "stuff," and tongue (not whole trailer) weight. The total shouldn't be much more than about 500 pounds. Good luck. BTW, I read your sig - a 169* stat?
Old Jun 6, 2002 | 12:40 PM
CptMorgan's Avatar
CptMorgan
Default Re: Ok, Will a C4 safely pull a small boat trailer (NavyVet)
NavyVet: 169* stat -> 169* Hyertech Thermostat.
Old Jun 6, 2002 | 04:19 PM
NavyVet's Avatar
NavyVet
Cpt Morgan - thanks. Guess I'm used to 160/180/195/etc.
Old Jun 6, 2002 | 04:58 PM
LPDesRoche's Avatar
LPDesRoche
I have seen it done many times you will be ok.....it just doesn't look right.
Old Jun 6, 2002 | 09:41 PM
BBA's Avatar
BBA
It will pull it ok...if you have the auto, leave it in third ( not OD ).
Old Jun 6, 2002 | 11:35 PM
jfb's Avatar
jfb
My 87 manual says not to tow anything. Now why do you think the designers of the Corvette recommend that? and also do not provide ANYTHING to attach a tow hitch? Also, did you ever bother to read the conditions (fine print) of using a rental tow bar? You absolve the renter of any liability when you sign the contract. :eek: A word to the wise should be sufficient, but in some cases many words will be insufficient. I read about those in the paper all the time.
Old Jun 6, 2002 | 11:53 PM
GRX's Avatar
GRX
Please don't. :jester
Old Jun 7, 2002 | 12:38 AM
NoWorries's Avatar
NoWorries
Default Re: Ok, Will a C4 safely pull a small boat trailer (jfb)
No Offense JFB, but I don't think Cheby engineers really knew what they were doing with a lot of things in this car. It is perfectly capable of towing small loads, even with the alluminum sub-frame.
I have a Reese, the biggest problem is that the spare tire carrier doesn't fit with the stock retainer. You have to cut the carrier up pretty good, and install a lock-washer, but its not too hard.
Old Jun 7, 2002 | 01:51 AM
  #33
CptMorgan's Avatar
CptMorgan
Default Re: Ok, Will a C4 safely pull a small boat trailer (NoWorries)
I installed the trailer hitch on the vette in the first week I owned the car.I carry my mountain bike all the time. I do alot of riding and the bike looks sweet on the back of the vette. The hitch installed very nicely without having to touch the car other than drilling the bolt holes. However, I had no idea Corvettes had aluminum subframes untill I went to drill the first hole!
Old Jun 7, 2002 | 02:08 AM
  #34
vettl83's Avatar
vettl83
Here in Wyoming we use 3/4 ton and 1 ton pickups for towing i.e. horse trailers, 5th wheel trailers, car trailers, boats etc. But seriously doing all of the formentioned with my Mopile diesel, wet boat ramps are tough on rear tires, your spinning them unintentionally. Also you need to check the rear differential to make sure you haven't drawn in any water through the vent if you submerge it. There are two happy days in a boat owners life, the day he buys it and the day he sells it. I'm still waiting for my second happy day. Good luck 91 ZR-1 #2039 :eek:
Old Jun 7, 2002 | 08:13 PM
  #35
GlockLT4's Avatar
GlockLT4
Default Re: Ok, Will a C4 safely pull a small boat trailer (vettl83)
GET A TRUCK !! :crazy: :crazy: :crazy:
Old Jun 12, 2002 | 01:33 PM
  #36
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Ok, Will a C4 safely pull a small boat trailer (JonM)
I think you have had one too many Capt Morgans....who wants to volunteer to swap him behind the head?
Yup, sounds like he's got a little "Captain" in him, alright! :lol:
Old Jun 12, 2002 | 02:03 PM
  #37
tarheelracer's Avatar
tarheelracer
Default Re: Ok, Will a C4 safely pull a small boat trailer (Glock'94)
It's got enough torque. The only problem I see is having to submerge the back end when backing the boat into the water. I tow my Sea-Doo with a Grand Cherokee and the back bumber gets wet when backing it in. As you can tell in the picture there's a major clearance difference.
To Ok, Will a C4 safely pull a small boat trailer
Old Jun 12, 2002 | 11:52 PM
  #38
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Ok, Will a C4 safely pull a small boat trailer (tarheelracer)
Pulls mine just fine. Of coarse you will need a large wing to keep the back end down when pulling it up the ramp, hahahahahaha.
Old Jun 13, 2002 | 12:39 AM
  #39
CptMorgan's Avatar
CptMorgan
Default Re: Ok, Will a C4 safely pull a small boat trailer (Bob86ZZ4)
Thanks bob! I forgot I'd seen that picture before. How do you like that boat?
Old Jun 13, 2002 | 08:10 PM
  #40
Bob86ZZ4's Avatar
Bob86ZZ4
Love the boat! Twin jet engines, 14', fly's off houseboat wakes, great pulling skiers, safe around the kids since no propellers. Going skiing this weekend, can't wait.
