93 Transmission shifting Problem
Old Oct 10, 2012 | 10:50 PM
kwbond1's Avatar
kwbond1
8th Gear
Default 93 Transmission shifting Problem
My wife has a 93 40th ANV, ATM, 65,000 miles, that sits in the garage 80% of the time. I decided to drive it, to blow the dust off. Vett was running great, hwy speed 70mph. then the traffic jam, slowed me down to a stop. When traffic cleared, the Vett would not shift out of 2nd gear. Drove 5 miles at 35mph to my work. Checked the Trans fluid, its fine. Nice clean red color. On the way home I climbed up to 45mph pushed shifter into "N" then back into "D" and it shifted into 3rd. At 56mph I did the same thing 3 times, and it shifted into 4th, if I release the gas, its like you steped on the clutch, and the RPM goes all the way down to Idle, car is coasting,,,,,???? I have no clue, any Ideals? I have searched the forms and did not read anything like this, did I miss it? Can some one direct me to my next step before my wife drives it and blames me for hot rodding it, Thank you, Kyle
Old Oct 11, 2012 | 08:08 AM
kwbond1's Avatar
kwbond1
8th Gear
will do this morning,,,,Thanks
Old Oct 11, 2012 | 02:02 PM
FrankieD's Avatar
FrankieD
he's driving an automatic not a 6 Speed ZF.
Old Oct 11, 2012 | 03:19 PM
tunedport85inject's Avatar
tunedport85inject
Assuming none messed with the tv cable in your 4l60,another known issue may be a stucked TV plunger inside the TV bushing.
To solve this problem you can find shift kit with a little aluminum plate that goes into the TV bushing and regulates plunger excursion inside valve body preventing it to get stucked,this pic show you a shiftkit by transgo this little plate is what cures a stucked TVvalve
Also I would ceck the governor,your symptoms aren't a worn out 2nd clutch pack,it seems to me more pressure and valves related.
http://www.thirdgen.org/techboard/tr...lem-700r4.html
Old Oct 12, 2012 | 05:49 PM
kwbond1's Avatar
kwbond1
8th Gear
It started shifting today but real hard. I have decided to let the experts look at it,
He will clean and change fluids, then test drive,,,,,we will see,,,,thank you for all the help, I will update once its fixed. yes by a corvette Tech
Old Oct 29, 2012 | 08:50 PM
kwbond1's Avatar
kwbond1
8th Gear
Ok Here what we found. Pulled the trans pan, the bottom was full of sluge, I guess its from sitting for long periods of time. We cleaned the pan, cleaned the valve body, put new fluid, shifting GREAT
I will drive it at least once a week now to keep it in check.
Thank you all for your help.
To 93 Transmission shifting Problem
