It is nice to finally spend a whole day in the garage. I got her running !
turns out it was a starter and a wire short to ground.
I had the starter from my 1985 parts car on the shelf in my garage so i swapped it out. still wouldnt start....
but it turned over. had no pressure at the rail.
fuel pump had power but no signal. the ecu wasnt powering the fuel pump turns out the ecu had no power. to the fuse panel checked good.
turns out going to the fuse panel the wire short causing .
Awesome man,good to know you fixed it ! I was asking because I have a friend with similar issues he's had for weeks. I'm not very familiar with the car so I'm researching what I can to better guide him in his success.
