Blinking "SYS"
Old Jun 4, 2002 | 09:04 PM
fourthrail's Avatar
fourthrail
Default Blinking "SYS"
On a 91, "SYS" blinks intermittantly while car is running? What does that mean? Battery?
Old Jun 4, 2002 | 09:38 PM
foliva's Avatar
foliva
Default Re: Blinking "SYS" (fourthrail)
I had the same thing happen on my '93. It was due to a blown fuse
on the radio. As soon as I saw it, I went around the car checking the
function of all the systems & found the radio inoperative.
In my case, replacing a blown fuse caused the new fuse to blow. Turned
out to be a wire in the harness was rubbing against a metal bracket under
the dash & wore away the insulation. Went nuts finding it.
Hope this helps.
Fred Oliva
Old Jun 4, 2002 | 10:21 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Could be the battery, also a blown fuse. Does the car make a buzzing sound with the key in, engine off and door open? If so, you have a blown fuse.
When I had the blown fuse, anytime I tried to turn on the light that had the blown fuse, the "SYS" would start flashing.
Old Jun 4, 2002 | 10:27 PM
hotwilzz's Avatar
hotwilzz
that will also happen if you have an aftermarket stereo due to a change in the wiring config. if that is the deal, there was a fix posted a long time ago, you may want to try a search
Old Jun 4, 2002 | 10:58 PM
Jasin9687's Avatar
Jasin9687
Default Re: Blinking "SYS" (hotwilzz)
the same thing is happenin in my 96, happened rite after I put a aftermarket stereo in it, there was a fix posted for me, I havnt got around to fixing it ( now that I know what it is, Its not a big deal )
Old Jun 5, 2002 | 12:32 PM
fourthrail's Avatar
fourthrail
Default Re: Blinking "SYS" (foliva)
Stock stereo, I'll check the fuses when I can.
Either way, doesn't sound critical ... unless of course, I'm out and the battery dies.
Thanx again for all the help...
Old Jun 5, 2002 | 01:41 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
90% of the time, it means your battery is dying. I've had this twice, both times it's been a bad battery.
Old Jun 6, 2002 | 08:22 AM
Jasin9687's Avatar
Jasin9687
Default Re: Blinking "SYS" (94vette)
what should the battery be charging at? anyone know? I have a lt4
Old Jun 6, 2002 | 09:05 AM
Bartman's Avatar
Bartman
Default Re: Blinking "SYS" (Jasin9687)
My LT1 charges @ around 14.2. Hope this helps.
bart
Old Jun 6, 2002 | 09:16 AM
Jasin9687's Avatar
Jasin9687
Default Re: Blinking "SYS" (Bartman)
mine flucuates (spelling?) between 13.9 and 14.x usally, more of the time holding around 13.9... U think this is 2 low?
Old Jun 6, 2002 | 09:52 AM
Bartman's Avatar
Bartman
That sounds about right
To Blinking "SYS"
