Chip Burning
Old Oct 16, 2012 | 08:17 PM
vetteOnTheRun's Avatar
vetteOnTheRun
Default Chip Burning
Ok guys I just bought the moates software, burner, cables, and etc. I have never done any chip burning before. I am real good with computers and software(i have built my own). I really want to do my own tuning when I do my upgrades. Is there some basic information specific to our c4's that I should read to help me understand the process? I know some are thinking....leave it to the pros, that might be true. I just want to do this myself. I have a 93 auto with a .30 over stroker kit coming real soon, hot cam, 1.6 rockers, headers, vats delete and etc. Give me some pointers please. Thanks
Old Oct 17, 2012 | 12:24 AM
Cliff Harris's Avatar
Cliff Harris
It depends on how deeply you want to get into this project.
You can download the assembly language disassemblies of the firmware, but that is REALLY technical stuff that requires a LOT of background in programming and how microcontrollers work on the bits and bytes level.
The easiest way to go is with a high level graphical interface like TunerPro RT. With that software you still need to do a lot of work to learn which graph does what and when, but that's a LOT easier than looking at a bunch of hexadecimal numbers...
Old Oct 17, 2012 | 05:46 AM
vetteOnTheRun
Yeah I was looking at tunerpro rt. Those that have used it, I was wondering how user friendly it is?
Old Nov 3, 2012 | 05:31 PM
tunedport85inject's Avatar
tunedport85inject
"getting started" is easy,but create your own tune not...first you need your ecm # file .bin and your definition file .xdf.when you open your .bin and "select" your .xdf file tunerpro populates his interface with
scalars,flags and tables.hundred of fuctions in wich you have to set or own tune values:here thinghs become very hard if you don't have basic knowledge of this functions like BLM/INT,injectors pulse width,spark advance ecc.you can't simply try...but the lerning curve starts with simply modds like fan temperature start,injectors flow rate setting... ecc.
Tuning is a dinamic concept,you can't tune a modded engine working on your laptop with tunerpro at home...you need some hardware like an aldl cable.thinghs start with datalogging,recording data from engine sensors,using a base tune.you need test drive the car while you'r datalogging,at different rpm,load,ecc.then you can play your recorded data and see how engine runs...then try to "calibrate" BLM to match the famous 14.7 afr...Tuinerpro rt allows you to emulate so you can modify your tune in real time while your test driving the car,but this is a long lerning curve...
Old Nov 3, 2012 | 09:55 PM
JackDidley's Avatar
JackDidley
Its very user friendly. Five minutes after I got it in the mail, I burned a chip. That said, I did a lot of reading and studying before that. Go to thirdgen.org and read the stickies. Its a good place to start.
To Chip Burning
