Need some help here please.
Old Oct 18, 2012 | 07:46 PM
War Vet's Avatar
War Vet
Default Need some help here please.
ok, so the other day i stopped for fuel, car was running great all day. but after i stopped and fueled up my car would not start. once i got her home (towed) i did some troubleshooting, first thing i did was check for spark. i was good there. 2nd thing i did was check for voltage at the rear harness that connects to fuel pump pigtail. i am getting 10.5 volts there and my battery is at a constant 12.75. next i supplied 12v to terminal G of my diagnostic port and the pump kicked in right away. i have also looked at the relay. i compared it to a brand new one and everything SEEMS ok. my next plan is to run a wire to terminal G from battery power with an inline switch and see if it works. i really do not know where else to look. any info would be greatly appreciated. Thanks.
Jay
Old Oct 18, 2012 | 07:48 PM
War Vet's Avatar
War Vet
by the way, this is an 84.
Old Oct 18, 2012 | 07:53 PM
War Vet's Avatar
War Vet
to be more accurate my idea is to run a wire off of 12v source into a switch, have another wire coming off of switch to back side of termainal G. any thoughts?
Old Oct 18, 2012 | 09:29 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
When you put 12v to G would it start? When you first try to start it do you hear the pump come on for about 2 seconds? If you don't hear the pump for the 2 seconds check the relay, contacts may be bad.. LOL
Old Oct 19, 2012 | 12:26 PM
fredd1's Avatar
fredd1
Did you check the oil pressure switch and oil level? I believe the ECM needs a positive pressure permissive to trigger the fuel pump relay. You may have a loose OPS connector or broken wire.
Old Oct 20, 2012 | 12:00 AM
tombrammer's Avatar
tombrammer
I got a quart of water in the tank once after filling up, car would not start after that. I removed the fuel filter and no gas smell, it was pure water. May want to check the filter anyway.
Old Oct 20, 2012 | 09:57 PM
cuengineer's Avatar
cuengineer
Also, if you are putting a 12v wire in the circuit, you should probably be sure to include an in-line fuse for safety.
Old Oct 20, 2012 | 10:02 PM
dogfish246's Avatar
dogfish246
Check the neutral safety switch...
Old Oct 20, 2012 | 10:31 PM
ccrazor's Avatar
ccrazor
A problem with the neutral safety switch (or clutch switch) would prevent the starter from working and has nothing to do with the fuel pump..
Old Oct 20, 2012 | 11:01 PM
vetteoz's Avatar
vetteoz
If your OP switch is working ( have you checked it ? ) then it performs the same function as the manual switch you wish to add. Bypasses the relay and puts power direct to the pump.
Using terminal G puts power to the contacts on the pump relay anyway so you are not bypassing any possibly bad wiring
As above.
Link to the ECM is because the ECM monitors the pump voltage and can make adjustments if the voltage to pump varies ( pump volume / pressure changes )
Old Nov 2, 2012 | 08:03 AM
War Vet's Avatar
War Vet
sorry for the late update, was without internet for a while. so i did what i listed above and everything worked great. i am still unsure for the original root cause, but i am ok with a "hidden" fuel pump switch now... thanks for all the input as well.
To Need some help here please.
