Riddle me this
Because, it's all about the torque baby, you shift when your torque curve takes a major dive, and that happens around your horsepower peak.
Horsepower is all in your head, it's not real, it can't even be measured directly.
If horsepower is the President of the United States then torque is the Grunts in the trenches, and we all know who does the real work.
:seeya
But I have an L98 dyno sheet here showing peak torque at 2800rpm (315) and peak HP at 4100rpm (210)...
That's a pretty good spread...But the curve is already pretty steep at that point...
Personally, I have more respect for the 1989 350 TBI Chevy/Caddy that put out 400 #/ft torque than I do for a ZR1...
[Modified by Rich B., 9:11 AM 6/5/2002]
I built the engine described above. It put down 520 ft lbs to the rear wheels at 2800-3000 RPM, it ran 12.0's in the 1/4 mile at 113-114 MPH, it only made 300 HP at the rear tires.
I took the same shortblock and heads, put a single plane intake, 1 3/4" headers, and a .590 lift cam and now it runs low 11.0's.
A heap of torque in a narrow RPM band is nothing compared to a modest amount of torque all the way across your RPM range.
[Modified by Red94Vette, 9:23 AM 6/5/2002]
:seeya
Yes, you do shift when torque falls off. The question is whether your torque falls off at 4k or 6k, and where it starts. The torque from my LT4 kicks me in the butt about 2k RPM and goes strong all the way to the rev limiter.
