Need help with 86 emissions
Old Oct 23, 2012 | 05:57 PM
Black86 4+3's Avatar
Black86 4+3
6th Gear
Default Need help with 86 emissions
I have failed for hydrocarbons. The allowable is 220 and I ran a 240 then a 290 after changing 02 sensor and running injector cleaner.... I also ran it hard on the way there to blow it out, apparently it made it worse...... Any ideas? I know my car burns some oil, so maybe I should put some motor honey in to help? It's a tpi, any way to lean it out?
Old Oct 24, 2012 | 12:08 AM
1986coupe's Avatar
1986coupe
Is the car stock or have you done any modifications?
Does the car run rich? You may have a fuel pressure regulator problem. Have you checked the fuel pressure?
How old is the air filter?
Old Oct 24, 2012 | 01:40 AM
mtwoolford's Avatar
mtwoolford
vacumn leak ? lean misfire ? after plugging and replacing the various rotted vacumn lines on my 460 ford work truck with an edelbrock rpm manifold and cam, the HC's dropped from 1320 to 180, with a carb and no cats.
Old Oct 24, 2012 | 01:48 AM
SouthCoaster's Avatar
SouthCoaster
Hydrocarbons are unburnt fuel. You can fake it by retarding timing a bit (4 degrees btdc) but it may be ignition related. When is the last time you did plugs, wires, cap, rotor?
Also there is some products on the parts store shelf that burn cleaner and easier than regular gas, designed to help pass smog. And make sure to run regular, not premium. I usually sniff really clean but I passed my last smog inspection within 1 ppm of the limit.
Old Oct 24, 2012 | 08:48 AM
Black86 4+3
6th Gear
I just found a 1/2" vacuum hose that became disconnected from the bottom of a valve just above the A/C compressor. Hopefully that does the trick.
All the ignition parts are new on the car and everything is bone stock. I will def try regular gas this time, I don't think these cars are too picky anyway when it comes to Octane.
Thanks for the help, I'll keep everyone posted.
Old Oct 26, 2012 | 08:03 AM
Black86 4+3
6th Gear
Wow.....It got worse......I ran 87 in it and fixed the vacuum leak, now it blew a 403 when the allowable is 220........Each time I take it, it seems to get worse....I'm starting to think the cat may be bad? any other ideas?
Old Oct 30, 2012 | 12:20 AM
1986coupe's Avatar
1986coupe
Are you getting any codes? Does it burn oil?
The cat may be bad...does it show any symptoms of running bad?
Old Oct 30, 2012 | 01:03 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
You in kali? No info in your profile....
Did you drop the timing back?
Old Nov 2, 2012 | 01:31 PM
Black86 4+3
6th Gear
She burns a quart about every 800-1k. She seems to run pretty good, so I'm not sure why it fails the tests so poorly.....
I'm in NJ by the way, I'll update my profile.
I'll check into the timing, maybe regap the plugs while I am at it.
Thanks everyone!
To Need help with 86 emissions
