Harness Bar gripe
Old Jun 5, 2002 | 06:31 PM
steveelsbury's Avatar
steveelsbury
Default Harness Bar gripe
Hi Guys,
Just bought a chrome harness bar from Ecklers, which turned out to be an Arizona Speed and Marine product.
Must admit I got it more for the look of the thing then for any burning need for a harness - although clearly there will be a harness :cool:
Anyway, what they don't tell you in the Ecklers catalogue is that it fixes to the roof rear mount points as well as the seat belt mounts. The problem is that the stock roof bolts are too short to go thru the brackets as well as the roof, and the new ones they supply *have a different size head* - how stupid is that? :mad
So know I have to carry a socket drive with an allen key socket as well as the standard roof tool. Also, you have to take the bolts out completely to get the roof off, and you need a second person to help you put it back on again, as they have to hold the brackets out of the way.
It does look great, but I may end up selling it because of the hassle of the above.
Just though this might save someone else making the same mistake.
Steve
Old Jun 5, 2002 | 06:35 PM
95AquaC4's Avatar
95AquaC4
Default Re: Harness Bar gripe (steveelsbury)
All the above was true for me as well, but I never remove my roof. For those who do, It will be a pain. Very nice harness bar though!!
Old Jun 5, 2002 | 07:40 PM
Jasin9687's Avatar
Jasin9687
Default Re: Harness Bar gripe (95AquaC4)
yeah I got one for my 87, I never take the top off, I like to be "inside the car" but I understand where your comin from, seems like a pita to me
Old Jun 5, 2002 | 09:48 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I came close to buying the AS&M, but went with Exotic Muscle instead. If it wasn't chrome, I would consider buying it from you, I want one for my other C4.
Old Jun 6, 2002 | 03:16 AM
pablocruise's Avatar
pablocruise
It does sound like a PITA. But how is the handling of the car after installation? Us California guys take our roofs off very frequently. That's why I won't be considering it. (next project=roll cage)
Old Jun 6, 2002 | 09:05 AM
steveelsbury
Default Re: Harness Bar gripe (89 Paul in Cal)
Yeah, I suppose a removeable roof (and air con) in the UK is very little use most of the time :(
As to handling, can't say yet as the Beast is incomplete. Should have her running this weekend. All that's left is coolant fill, start and timing. I don't expect the bar to make much difference, as although it is clearly strong enough to take the harnesses, it doesn't seem all that rigid.
It looks fantastic though!
Steve
Old Jun 6, 2002 | 10:56 AM
pabarny's Avatar
pabarny
How about some pics of your bar. It's always nice to show off chrome.
Old Jun 6, 2002 | 11:35 AM
steveelsbury
Default Re: Harness Bar gripe (pabarny)
It's hissing down with rain at the moment, but as soon as it clears up, I'll take a couple and post them here.
Old Jun 6, 2002 | 11:48 AM
steveelsbury
Hey - the rain stopped!
Try these for size:
Please ignore:
1. The fact that my headlining has had it
2. The fact that I forgot to put the seat-belt bracket covers back on (just noticed)
3. No comments about a rice sound system please :rolleyes:
Old Jun 6, 2002 | 01:22 PM
BBA's Avatar
BBA
Does the bracket block the light from the rear cargo lights?
Old Jun 6, 2002 | 01:31 PM
steveelsbury
Default Re: Harness Bar gripe (BBA)
Yes.
However, the brackets at that point are about an inch away from the body, so you still get light from around the sides of the bracket.
[Modified by steveelsbury, 6:31 PM 6/6/2002]
Old Jun 6, 2002 | 01:35 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Hmmmmmm that's really weird??? I bought the same harness bar at Carlisle last year and mine don't have those top brackets??? :confused:
I guess it's a good thing!
Old Jun 6, 2002 | 01:38 PM
steveelsbury
Default Re: Harness Bar gripe (Mr. Magoo)
It's clearly not the same harness bar then! Your upright 'loops' are wider then mine, and it looks like you have two brace bars running down to the back of the roof holders in the cargo area?
There must be braces there somewhere, otherwise the bar just rotates around the seat belt mount points, no?
The sharp-eyed amongst you may have noticed that when I bent the top retaining bars up into position, the chrome flaked off where they are welded to the 'loops'.
Bugger - the design of yours looks better then mine! :cry
[Modified by steveelsbury, 6:40 PM 6/6/2002]
Old Jun 6, 2002 | 01:45 PM
IcemanZ06's Avatar
IcemanZ06
The car I just bought has an AS&M harness bar. Didn't realize that was how it mounts. May have to take a look at it and reconsider the bar since I like to take the roof off.
How much more rigid is your car with the bar?
Old Jun 6, 2002 | 02:02 PM
Mr. Magoo's Avatar
Mr. Magoo
Wow your right! :eek: I'll check my receipt when I get home from work, maybe it's from another manufacture???
Old Jun 6, 2002 | 02:16 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
You don't really need this part of the harness bar, do you? It looks sturdy enough that you could cut those off and it wouldn't make a difference.
Old Jun 6, 2002 | 02:37 PM
steveelsbury
Default Re: Harness Bar gripe (War Machine)
Without it, the bar swivels around the seat belt mount point.
To Harness Bar gripe
Old Jun 6, 2002 | 09:22 PM
Mr Mojo's Avatar
Mr Mojo
Mark, my guess is that you have the Terry Farber bar.
Old Jun 6, 2002 | 09:27 PM
IcemanZ06's Avatar
IcemanZ06
Default Re: Harness Bar gripe (Mr Mojo)
would it be possible to still remove the top by unscrewing the outer two bolts? That way the whole latch just stays in place and the top just lifts out. :confused:
Old Jun 7, 2002 | 06:45 AM
steveelsbury
Default Re: Harness Bar gripe (IcemanZ06)
Don't know - I'll try it.
You can still take the top off, but have to replace the bolts with the roof off to hold the brackets. Also, you need another person to help replace the top, as the brackets get in the way.
