ASP Crank Pulley
Old Jun 6, 2002 | 03:22 PM
damionvoss's Avatar
damionvoss
Default ASP Crank Pulley
Just ordered an ASP crank pulley and new belt for my '85. Just wanted to know if it is a simple, straight forward swap, or if there are any tricks I need to know? Hopefully, this will help to stop me from overspinning my supercharger! Thanks!
Old Jun 6, 2002 | 07:26 PM
TA's Avatar
TA
Default Re: ASP Crank Pulley (damionvoss)
A lift will help a lot when putting this thing in. I did mine a few weeks ago and we had to remove all the bolts from under the car. Then once it was loose it was necessary to remove the tensioner and water pump pulley to get the crank pulley out of there (removed that from the top). It wasn't a difficult job, just a little more time consuming then I originally anticipated.........but I guess that's the way most things go :crazy: Good luck :cheers:
