Where is the oil pressure sensor or switch on an L98 ???
Actually I meant oil temperature switch. I thought it was by the dipstick between the 6 and 8 sparkplug but i think that is the knock sensor.... any help ???? :crazy:
[Modified by jm88vette, 4:51 PM 6/6/2002]
Re: Where is the oil pressure sensor or switch on an L98 ??? (corvette0096)
Drivers side of distributor. Mine makes a T and has two sensors on it. One was the oil pressure and I think the other may have been oil temp.
Location: And on the fifth day, subpoenas were served to Obama senior staff
1 Post
Re: Where is the oil pressure sensor or switch on an L98 ??? (jm88vette)
Well if you mean the oil temperature sensor that is above the oil filter.
Oil pressure switch and oil pressure sensor are behind the engine near the distrubutor.
:D
:D
Re: Where is the oil pressure sensor or switch on an L98 ??? (PeteL)
What Pete said. The larger sensor behind the distributor is oil pressure. The other is a safety switch which will kill the engine if the oil pressure gets too low.
[Modified by Muffin, 6:13 PM 6/6/2002]
1 Post
Re: Where is the oil pressure sensor or switch on an L98 ??? (Muffin)
You know, I can't find a thing in the manual that says that oil pressure switch does anything except back up the fuel pump relay! I don't think it will stop the engine with 0 oil pressure.
