changing spark plugs
Old Jun 6, 2002 | 05:45 PM
derv3tt3's Avatar
derv3tt3
Default changing spark plugs
My 94 has 20,000 miles on it and as far as I know the plugs have never been changed anything to watch out for? I have heard a lot of bad stories about stripping threads out of the heads.THANKS :rolleyes:
Old Jun 6, 2002 | 08:18 PM
olephart's Avatar
olephart
Default Re: changing spark plugs (derv3tt3)
I didn't have any problems at that mileage, with the original plugs (they come with anti-sieze). Put some anti-sieze on the new ones and you won't have a problem in the future.
Old Jun 6, 2002 | 08:46 PM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
Just make sure you do it when the heads are bone cold. Like sitting at least overnight. And be sure not to crossthread them when going in. To avoid this, you might want to install them by hand (as opposed to using a socket) until you know they are in several turns and have threaded properly.
Depending on how **** you are, you might want to chase the threads while using some 2+2 and blow the stuff out the spark plug holes by turning her over a couple of times w/o the plugs installed. I only say this because they are nearing 10 years old, maybe some crud has built up in the threads over time...
Old Jun 6, 2002 | 09:17 PM
derv3tt3's Avatar
derv3tt3
Default Re: changing spark plugs (TrueBlue ChevyDude)
Thanks for the replies,I'll give it a try. :seeya
Old Jun 6, 2002 | 11:57 PM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
One way to help keep from crossthreading is to start by turning them counter clockwise until you feel a little click, then start turning them clockwise and the threads should catch......
Just a little something that a machinest once taught me......
Old Jun 7, 2002 | 01:23 AM
CG77VETTE's Avatar
CG77VETTE
Another way to prevent cross-threading is to use a 12" length of vacuum hose. Press the hose over the top of the plug (where the wire attaches) and install the plug by turning the hose. If the plug is cross-threaded, it will slip inside the hose and not thread at all. This also makes it easier to install the plugs given the limited space. Hope this helps.
Old Jun 7, 2002 | 01:32 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: changing spark plugs (CG77VETTE)
If you have never changed the plugs before, you will find this a challenging process.. Try removing the wheel wells to gain easier access to the plugs.. along with all the tips from everyone else to avoid cross threading, etc.. Oh, and a few beers never hurt making the job more enjoyable!! :D :cheers:
-Mark
Old Jun 7, 2002 | 07:37 AM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
I add wheel bearing grease to my plug threads when installing the plugs. When I remove the plugs they come out very easy and there is very little of a chance to cross thread the threads. Also, The plugs will not loosen up with the wheel bearing grease on them. I use just enough to cover the threads.
Old Jun 7, 2002 | 04:41 PM
derv3tt3's Avatar
derv3tt3
Default Re: changing spark plugs (89NYFINESTVETTE)
Thanks for the replies , I've changed plugs before but not from an aluminum head thats never had them removed.Just nervous. :rolleyes: :seeya
Old Jun 8, 2002 | 10:16 PM
Jay Axson's Avatar
Jay Axson
Have fun, there is zero room to work or see. I'm doing them now as part of a hotcam upgrade. I've done the easiest one and it was slow going. I am not looking forward to the rest. :cry :nopity
Old Jun 8, 2002 | 10:35 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: changing spark plugs (Jay Axson)
Aluminum heads are more fragile than their cast iron counterparts. Anti seize is probably the best remedy. But use it sparingly. You don't want that stuff going down to the piston rings. Probably best to do exactly as "..ChevyDude.." said. He has the method down pat. I have only experienced one stripped sparkplug thread in my life. It was on a motorcycle that the kids practiced working on. It seems that they used an impact to remove the plug. I had to reweld the head and machine new threads in to it. A lot of work for carelessness. So be careful. Afterall it is your car and you want to do it right.
:seeya :seeya
Old Jun 8, 2002 | 10:55 PM
Fletch54's Avatar
Fletch54
take the wheel wells out it makes it alot easyer. I did mine today.
Good luck
:crazy:
Old Jun 9, 2002 | 11:21 PM
derv3tt3's Avatar
derv3tt3
Default Re: changing spark plugs (Fletch54)
Looks like the passenger side is the easiest,but looks are deceiving. :rolleyes: :seeya
Old Jun 9, 2002 | 11:44 PM
GS 163's Avatar
GS 163
On the drivers side only, the passenger isnt too hard to do. The first time is always the hardest, after that it becomes a piece of cake.:)
Old Jun 10, 2002 | 05:52 PM
derv3tt3's Avatar
derv3tt3
Default Re: changing spark plugs (JPLT1)
Passed e-check today :D :lol: but have noticed gas mileage has gone down so I better get to the plugs.
Old Jun 10, 2002 | 06:08 PM
cprgmr's Avatar
cprgmr
I just got done doing NGK plugs and Taylor wires last week and the wires on the driver's side were a complete PITA! The hardest plugs to do are #7 and #8 due to the confined space to work in (almost stripped both of them). But like others have said in earlier posts, once you get done doing it the first time, it seems like it's not that bad of a job. :) Be safe and use anti-seize on the threads when putting them back in by hand.
[Modified by cprgmr, 4:09 PM 6/10/2002]
Old Jun 10, 2002 | 11:20 PM
derv3tt3's Avatar
derv3tt3
Default Re: changing spark plugs (cprgmr)
A new battery and spark plugs, but not to sure about wires.
CPRGMR,you have trouble with 7 & 8 going in or coming out? :seeya
Old Jun 11, 2002 | 12:19 AM
cprgmr's Avatar
cprgmr
Coming out - they were really in there! On #7, I almost completely stripped the plug. I just happened to get lucky and finally got a good enough grip on it and turned it verrryyyy slowly. I was really sweating bullets on that plug! :eek:
To changing spark plugs
