speedo wrong-how can i fix it?
Old Jun 6, 2002 | 07:44 PM
republicanhunk's Avatar
republicanhunk
Default speedo wrong-how can i fix it?
hi gang,
i have a 93 that has new rims and tires on the front, but that has caused my speedometer to be inaccurate. any ideas on the remedy would be appreciated :)
Old Jun 6, 2002 | 07:46 PM
republicanhunk
Default Re: speedo wrong-how can i fix it? (republicanhunk)
lol, by the way,its not just new tires and rims on the front
Old Jun 6, 2002 | 09:15 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Now you got me confused!
I did a gear swap on my '93, there are some plastic gears in teh rear of the tranny that can correct the speedo. But if you just did a tire swap, it can't be off by that much unless you went with taller tires. Also the front ones shouldn't affect it at all. Your tire sensors for the ABS and ASR may be off due to uneven tire sizes.
Old Jun 6, 2002 | 10:19 PM
republicanhunk
Default Re: speedo wrong-how can i fix it? (Mr Mojo)
actually, i bought the car not that long ago, and i had assumed they just swapped the rims etc. i knew the gear change was a possibility, but the person i bought it from didnt know. i have seen those lists of speeds depending on the tire size and gear, but know i have no idea, except to just shadow someone :) thanks for the help!
Old Jun 7, 2002 | 01:58 AM
HighHopes85's Avatar
HighHopes85
Get on I 65 and head north past the construction. Set cruise control at 60 MPH and have a buddy with a stopwatch time in between 5 mile markers. That would be the quickest way to check.
Old Jun 8, 2002 | 12:48 AM
mfranco's Avatar
mfranco
Over here in Ohio the police use fixed radar machines that display your actual speed for auditing driving speeds on certain roads. They are not used for giving tickets but just for auditing purposes. You could probably call your local police department and see if there are any of these in your area.
By the way, I hope you didn't purchase your car from Ideal Corvette over there in Indy. If so, good luck.
Old Jun 8, 2002 | 12:51 AM
republicanhunk
Default Re: speedo wrong-how can i fix it? (mfranco)
lol, i did stop there, but didnt buy one there. they tried to rip me off!
Old Jun 8, 2002 | 12:57 AM
mfranco's Avatar
mfranco
I wasn't so lucky. But now, after $4500.00 in repairs I do have a decent car.
Old Jun 8, 2002 | 01:01 PM
republicanhunk
they raised the price on me when i went to put down the deposit. 1000 in one day. i told them to fly a kite, i hope everything works out for you.
To speedo wrong-how can i fix it?
