Rear carpet falls down?
Old Jun 6, 2002 | 07:53 PM
sputnick's Avatar
sputnick
Default Rear carpet falls down?
Every time i take the car out for a ride the rear carpet falls down where it meets the privacy screen. Are there screws under the plastic moulding that are supposed to keep this thing from falling or am i just going to have to use double sided tape. Didnt want to pull the plastic off if it isnt going to help. thanks.
Old Jun 6, 2002 | 08:11 PM
greg84's Avatar
greg84
Default Re: Rear carpet falls down? (sputnick)
hi,you should have 2 or 3 large plastic clips that hold the carpet in.go to your local chevy dealer and they should have them in stock.good luck,greg84
Old Jun 6, 2002 | 08:17 PM
sputnick's Avatar
sputnick
Default Re: Rear carpet falls down? (greg84)
Plastic clips, eh? What do they look like. Odd that they would be missing.
thanks
Old Jun 6, 2002 | 08:30 PM
95wht6spd's Avatar
95wht6spd
I had this problem, carpet riped out from the screws and it has shrunk, so no way to reattach using same screws. I tried double sided tape, didn't work. Get some 3M spray adhesive at the auto-parts store, spray on back panel and underside of carpet (sprays out like lace, or a web) and this should do it.
Oh yea, don't let 2 girls ride in the back that you met in a bar, it could cause the problem again. :reddevil :smash:
Old Jun 6, 2002 | 08:34 PM
sputnick's Avatar
sputnick
Default Re: Rear carpet falls down? (95wht6spd)
The holes are ripped and the carpet is warped looking. I guess i'll have to watch out for those back seat passengers as well. :blueangel:
Old Jun 6, 2002 | 08:47 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Actually there are 4 of them and they are metal. I'm replacing the carpet in my '93 right now. The new(used) carpet was torn at the holes, but I put the clips on tight enough where the carpet won't even move.
Old Jun 6, 2002 | 08:52 PM
sputnick's Avatar
sputnick
Default Re: Rear carpet falls down? (Mr Mojo)
Could these elusive clips still be in the car? under the plastic panel?
Car is a 93 by the way
[Modified by sputnick, 7:52 PM 6/6/2002]
Old Jun 6, 2002 | 08:53 PM
JonM's Avatar
JonM
I used a couple of fender washers, screws, and plastic sleaves. Can't see them and works perfectly.
Old Jun 6, 2002 | 08:55 PM
Mr Mojo's Avatar
Mr Mojo
If you pull the plastic trim panel that covers the hatch latch, you should see some foam. under the foam is where the studs are located. The clips that mount on there are round with a star pattern in the middle. If the carpet has pulled out and nobody else has messed with it, they should still be there.
If it wasn't raining out, I would take a pic for you.
Old Jun 7, 2002 | 02:07 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I cut a new hole and used zip ties to connect the carpet to the screws. Looks good (can't see anything) and holds just fine.
Old Jun 7, 2002 | 03:47 PM
GlockLT4's Avatar
GlockLT4
My rear carpet does the same thing too. I hate it. I've tried several things, but i think adding some new different clips might help it.
To Rear carpet falls down?
