cam choice
Old Nov 10, 2012 | 12:32 PM
mcm95403's Avatar
mcm95403
Default cam choice
I'll be pulling the engine out of the 91 this week due to the dead rings. I have a great low-miles 87 engine that I will swap out the bottom end with. I have a set of Fast Burn heads on the way and will have my Accel intake welded up to fit the heads.
I need a cam with will give a littel more "oomph" and work better with the Fast Burn heads than the stock L-98 cam, BUT I'm in Kalifornia, so I need something with a good/pretty smooth idle that will pass smog.
I'm going to do a 2200-2400 converter and have 3.07 gears. I may auto-x it once a year or so, but realisitically, I drive it 20K miles a year, and I want smooth and flexible more than I want race car.
I'm looking at the ZZ4 cam since I can't find a good LT-4 cam for a reasonable price. TPIS has a small cam but it's only .420 lift and the ZZ-9 cam looks bigger than I want.
Anyone who's run a ZZ4 cam in a similar setup (and especially if you passed CA smog with it), please chime in.
Thanks,
Marc
Old Nov 10, 2012 | 12:36 PM
as long as it is red's Avatar
Check out my cam in my post .
Old Nov 10, 2012 | 12:37 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Got a new Accel 219/219 in the box
Old Nov 10, 2012 | 12:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
Dont think the ZZ4 over stock would be worth it.
ZZ9 would be a safe bet on smog and work well, idle nice too.
Those heads have real good airspeed so you can run a not big cam with them and they will work great with it.
Old Nov 10, 2012 | 12:52 PM
mcm95403's Avatar
mcm95403
What are the specs on it? 219 sounds way too big for what I'm wanting.
Old Nov 10, 2012 | 01:12 PM
TA's Avatar
TA
1.5 ratio rockers 1.6 ratio rockers
intake / exhaust intake / exhaust
Gross Valve Lift .525" / .525" .560" / .560"
Duration @ .006" 280" / 280'
Duration @ .050" 219' / 219'
Lobe Lift .350" / .350"
Cam Lobe Center 112'
Intake Center Line 108'
Valve Timing @ .050 open / BTDC Close / ABDC
INTAKE 1.5' 37.5'
open / BBDC Close / ATDC
EXHAUST 45.5' -6.5'
Old Nov 10, 2012 | 01:24 PM
mcm95403's Avatar
mcm95403
INTAKE 1.5' 37.5'
EXHAUST 45.5' -6.5'
Yep, that is too big for me.
To cam choice
