knock sensor woes :(
I get a periodic code 43, mostly when letting off the throttle at around 60 mph. The light stays on for about 4 minutes then usually goes off. I have ran about 3 tanks of Shell 93 octane through it to flush out any old gas.
Last night I installed a new Delphi knock sensor and a new plug since mine was damaged. The old sensor was old! maybe the original.
Anyway, I fired it up and headed home and let off the throttle on a long downhill and that darned light came on again
Drove it for 20 miles and stopped for a minute, everything was good. Left it running while going inside and came back out and that darned SES light is on.
Drove it again yesterday and everything was perfect. Pulled in the driveway and hopped out and left it idling, came back to the car and the SES light is on again
It is always the pesky knock sensor and now seems to trip when idling for a while after it gets hot.
If you have a bad exhaust manifold, they leak more when cold as do gaskets.
Generally, knocks are caused by a lean condition or carbon build-up or bad timing.
So, assuming knock sensors are working correctly, suggest checking other things:
e.g. vacume leaks, loose spark plugs (11 lb ft), bad fuel injectors (ohm each).
Also, check the ICM (ignition (coil) control module) -- small electronic device near coil, check for loosesness, proper torque (inch pounds), heat sink paste behind it and heat sink. Can also remove and have tested as it affects timing of spark to plugs via the Opti (e.g. Autozone, O'Rielys).
I had a problem with my vette knocking, which never used to be an issue until i had a problem and was throwing parts at the car. Needless to say the car was out of action for around six months, and the knocking started in the following summer. A long story short i found a esc module when i was cleaning the garage, and wondered which was the original one.
It had turned out the part which i thought was correct was for for a later model c4, i put the correct one in no more knocking when hot weather and a/c resulted in some knocking with high coolant temps.
Have since learned esc modules were matched to the knock sensors also.
Food for thought. see link.
http://forums.corvetteforum.com/c4-t...-the-same.html
