Help , 0 compression in #5
We're not going to discuss my education tuition over the years...
I gotta hand it to ya, you;re sure staying positive and objective ! I'd have been in the padded cell again if this had happened to me
years ago,
I recall a new paint job...that sexy deep blue that came on the Impala SS many yrs ago and a few vettes. GS colors I think..anyway,
Less than 1 week later I parked up under the back end of a Pick-up truck with a drop down ball hitch...went about 3/4 of the way up the hood. Like a chain saw had run up the hood...
I was in therapy for months.....
I'm glad that you;re coping better ! Few things hurt worse than your Corvette being injured..
Let us/me know how we can help.
I'm in the process of reassembling the engine. The piston/rings/rodbearing have been replaced on the bad cylinder. There was a really small rub mark on the wall. If it has a compression within 10% of 180 PSI I'll be thrilled. If not I'm done. 53 years of working on cars I no longer enjoy it. Remember this was a new short block. The AFR heads have been checked by a engine builder. On new years day I'll replace the intake manifold. I'm also buying new injectors just in case. The only defect I found was a torn intake gasket on #5 piston runner. The bad cylinder. Then within a couple of days I'll replace the super ram. Within a month I should know the results.
As you can see it takes effort due to lack of desire for me to work on the car. If it works out I'll race another year if not I'll sell or part out the car.
Thanks again for all comments and after everything is up and running I'll post the results.
A compression check of all cylinders resulted in 195PSI +/- 4PSI. While I had the heads off I had them checked out and 0.010" machined off. The previous compressions were 182 PSI with a estimated compression of 9.5 : 1. What compression would I expect with the listed cylinder pressures?? Racing the car previously I used 93 octane pump gas. I expect I'll need to mix some 100 octane with the pump gas??? Yes / no???
Again THANKS FOR ALL INFO
I want to thank you guys for convincing me that indeed the race oil pan would indeed come off without removing engine from car. It is easier than I would have believed.
A compression check of all cylinders resulted in 195PSI +/- 4PSI. While I had the heads off I had them checked out and 0.010" machined off. The previous compressions were 182 PSI with a estimated compression of 9.5 : 1. What compression would I expect with the listed cylinder pressures?? ....
Too many variables such as valve timing and overlap.
The time to calculate compression ratio is while the heads are off.
It involves taking precise measurements. They include:
Volume of the cylinder head chamber with the valves in place.
Volume of any depressions or protrusions in the piston.
Distance from top of piston(flat portion) to block deck at TDC and at BDC.
Cylinder bore diameter.
Gasket thickness. (Depending on how accurate you want to be, you would measure the bore diameter of the gasket too)
Basically you calculate the volume of the cylinder at BDC and at TDC then divide the two.
Shaving .01 off the cylinder heads will not greatly change your compression ratio. I don't know what the general measurements are for your engine, but I would guess an increase of maybe 0.1. (1/10)
If you are concerned about leaning out, get a wide band a/f gauge setup. This will let you know if the engine is not tuned properly.
Better yet, if you don't want the hassle, take you car to a good place that does dyno tuning and them tweak the computer for whatever fuel you want to run.
I'm glad it's all back together and that you didn't walk away from it.
Have fun.
Dont you love the fact that you could do this without removing the motor ?
