87vette NOSTART ???
Old Nov 22, 2012 | 08:34 AM
jesse_c4's Avatar
jesse_c4
Default 87vette NOSTART ???
Hello, My 1987 corvette will not start. If anybody could help it would be great. thank you in advance.
it all started one day i went to start my car in the garage. i turned the key and nothing...
all i hear is a realy clicking. starter wont power up..
the security light is flashing.
h e l p ! ! ! p l e a s e
Old Nov 22, 2012 | 09:06 AM
JackDidley's Avatar
JackDidley
The security is supposed to flash, thats good. See that the battery has at least 12 volts. If thats good, clean the cables at both ends.
Old Nov 22, 2012 | 09:19 AM
jesse_c4's Avatar
jesse_c4
battery has 12v.
im in the garage now. I will try to clean ends. thank you
Old Nov 22, 2012 | 09:20 AM
jesse_c4's Avatar
jesse_c4
I noticed when I try to start the anti-lock light flashes ?
Old Nov 22, 2012 | 09:28 AM
ghoastrider1's Avatar
ghoastrider1
you sure the battery has enough "juice"? tried to charge it or jump it? Turn on your headlights and try to start it...if the lights go out..the battery needs charging or replacing...if they stay bright or dim slightly..the problem is futher down the line.next in line of course, is the starter or bendix..which is on the starter anyway. I understand htere is a common problem with the "key chip". but dont know much about that, others will have to chime in on that.
Old Nov 22, 2012 | 09:42 AM
lt4obsesses's Avatar
lt4obsesses
If you have enough battery power, and all of the connections, terminals, grounds, and starter(connections), are good. Then you have a problem with the starter solinoid. That would be the clicking you hear, but it is not engaging the starter motor to turn the flywheel. This would be my first guess.
Old Nov 22, 2012 | 04:12 PM
jesse_c4's Avatar
jesse_c4
Default fixed
I got her started today.
turns out it was a wire short cause the ecu go go without power.
I found that out after I swapped the starter.
Old Nov 22, 2012 | 04:14 PM
jesse_c4's Avatar
jesse_c4
Happy Thanksgiving Corvette Fourm
Old Nov 22, 2012 | 04:17 PM
jesse_c4's Avatar
jesse_c4
yes, tha battery did need a charge. I switched to my spare battery
Old Nov 22, 2012 | 07:30 PM
JackDidley's Avatar
JackDidley
Same to ya.
To 87vette NOSTART ???
