Alternator question
Old Jun 8, 2002 | 01:12 AM
Tom73's Avatar
Tom73
Default Alternator question
If you install a higher output (amp) alternator, do you need to make any mods to the system to allow for the higher amps? Or does the system make its own allowances for the change?
tom...
Old Jun 8, 2002 | 12:05 PM
89 Bob L's Avatar
89 Bob L
Default Re: Alternator question (Tom73)
No modifications are necessary.
Old Jun 8, 2002 | 12:26 PM
RMWICK1's Avatar
RMWICK1
Agree, there should be no mods....the alternator just has the abillity to put out more amps and it will run cooler under load. It will do a better job in charging the batt and running all the applicances at the same time. such as new stereo amp that may draw big time on the system, especially at an idle. The only time you need to increase the wire size from the alt to bat is if your running an number 14 or 16...the line from the amp to system is a number 10 wire or bigger on a vette so your home free.
Bob
89 Vette in Stockton CA :smash:
To Alternator question
