Catalytic Converters
3 cats? if you have pre-cats, one on each tube just south of the collector under the manifold, I'd find a way to LOOSE 'em or hollow them out and make the main cat removable with a "test pipe". You can buy a new Y pipe thats a bit larger ID and its got no pre-cats...of course it comes with a paper that clearly states this is for OFF ROAD USE ONLY, and you have to promise Mr. Gore that you won't pollute the air that his gulf stream jet has to fly thru.....
HP..? some. The true benefit is how the engines power band is now distributed. The BIGGIE is throttle response.
Right now it hesitates a bit when you floor it. You may not think so, but it drags because there is a ton of resistance to a sudden gulp of air.That gulp has nowhere to go when the exit is full of pressure...so everything slows down.
Take those cats out (especially pre-cats) and you'll $hit yer britches then fall down in it !
The increased throttle response is dramatic and you won;t want to go back to "legal"..ever again.
It'll rev like a chain saw and that alone makes it seem like there is an extra 50 hp...while its more like 20...(honestly do not know for sure) the difference is very exciting to feel it respond like that. Tap the pedal, it jumps.
Just a word of caution....IF someone were to attempt to beat out a pre-cat or any other, that material is toxic and creates a bunch of fine dust as it breaks apart. If there is access to good welding equip, it might be worth it to cut it open then weld it back up, BUT that leaves evidence that someone did exactly that and you do not want to be caught with hollowed out cats.. For that reason and others I bought the "OFF-ROAD" Y-pipe...and keep forgetting to swap it out come monday...
What's between the ears, brakes, suspension (alignment), and tires will have a far greater impact, with the emphasis being on what's between the ears.
Have your exh manifolds been ported?
x3BUT- if you want to pick up power from the exhaust system the FIRST thing to do is to dump the crappy stock headers. I did LT-1 manifolds on mine a few months ago and it made a significant improvement. Minor fab work required, but you should still pass smog.
Look here: http://marcmedina.com/LT1manifolds.html
and several threads like this: http://forums.corvetteforum.com/c4-t...discovery.html
http://forums.corvetteforum.com/c4-t...-part-3-a.html
I'm not sure what kind of track days you're refering to, but if you're talking quarter mile, you will see quicker ETs by eliminating the center cat.
Also, as others have said, you'll see no codes, as there are no oxygen sensors after the cats on L98s.
the mufflers are long gone on my car and the exhaust flows out both sides. The Cats however are 130K miles and 22 years old.
Points issues? Sniffer Issue?
With the age of your converters and geographic location, 2.5" front Y with high-flows seem like the best option.
You won't have any code issues no matter what you do. With an aftermarket rear Y-pipe and old cats, I'd think you'd be looking at a 15-20rwhp bump with removal. Porting those manifolds and/or converting to LT1(s) is another option. (You can even have them extrude-honed if desired.)
On thing to note is that federal law prohibits the removal of a working cat even if you just want to exchange it for a high-flow version. Should a shop get caught removing cats from a car, they could face a 5-figure fine
As far as removing just the pre-cats and using a "test pipe", you may not see much of an increase in power. I run true duals, an x-pipe, and race mufflers on my 87 autocross car and there was a small gain but not much more than 5-8HP. Headers are on the install list for springtime and I would expect that this could bring as much as a 15-20HP gain. But I don't have to go thru any emissions testing.
Wouldn't be surprised if the intake becomes the HP limitation one exhaust get's better. Actually, you'd have to expect that.
