Engine Breakdown question
Old Jun 8, 2002 | 01:49 PM
PonyH8R's Avatar
PonyH8R
Default Engine Breakdown question
What are the plug things in this picture? Do I need them? Why are only some holes plugged?
Thanks.
:confused:
Old Jun 8, 2002 | 02:03 PM
chucks88's Avatar
chucks88
Default Re: Engine Breakdown question (kghott)
I had that same question about three weeks ago when I replaced my intake gaskets. I forget the reason, but the ones on both sides, toward the fire wall on mine were blocked off. Your new gaskets should come that way too.
Old Jun 8, 2002 | 04:06 PM
PonyH8R's Avatar
PonyH8R
Default Re: Engine Breakdown question (chucks88)
So no one knows why? Hmmmm..... Just strange that it is like this but the ports were made by the manufacturer. Still :confused:
Old Jun 9, 2002 | 12:40 AM
vettl83's Avatar
vettl83
It's to block off the exhaust cross over ref. closed gasket. Cast iron manifolds will run very cool when blocked off completely and aluminum manifolds will run very warm with no restrictions. Open gaskets are used when a choke is activated by a thermostat heated by the intake manifold. In other words your good. 84 CF 91 ZR-1 :cheers:
Old Jun 9, 2002 | 10:08 PM
PonyH8R's Avatar
PonyH8R
Default Re: Engine Breakdown question (vettl83)
Thanks!! Just wanting to know more about why things are the way they are. Makes me smarter. :lol:
To Engine Breakdown question
