harness bar?
Old Nov 27, 2012 | 08:02 PM
mxnuke's Avatar
mxnuke
Default harness bar?
Do harness bars do anything to stiffen up the c4 or are they just for belt mounts?Dont want to put a roll bar in the car unless i have to. the c4 game is new to me so i need some input.Going to do some standing 1/2 mile and 1 mile stuff just for fun.Any pics of bars will help..thanks..Dennis
Old Nov 27, 2012 | 10:24 PM
AirForceOne!'s Avatar
AirForceOne!
I think they are mostly to hook up racing harnesses to for autocross? They may add some stiffness, but I don't believe that is their intended pupose! I think some autocrossers will chime in!
Old Nov 27, 2012 | 11:22 PM
blakngold4life's Avatar
blakngold4life
I put mine in for the restraints, not for extra stability. Autocrossing there was no noticeable difference in terms of handling, but the control and feel of having the harness is amazing. There are enough things going on while on the track, eliminating having to figure out how to position yourself is well worth the extra weight of it in my opinion. I dont know how a harness would effect straight line feel, but for the speeds you will reach at a standing mile I would consider a full cage, too much can go wrong fast.
Old Nov 28, 2012 | 02:05 PM
383vett's Avatar
383vett
I have a chromoly 5 point rollbar. Serves as a harness mount and keeps the top intact in case of the dreaded rollover.
Old Nov 28, 2012 | 05:46 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I've had one in my 86 for years. It may add a little stiffness, but having a harness to hold you in the seat when doing track days makes a big difference. If you decide to get one, get the extensions that set it back further. Otherwise its right behind your head. Bad news if you get rear ended without your helmet on.
Old Nov 28, 2012 | 07:00 PM
armysnipe's Avatar
armysnipe
It's my opinion that my Brey Krause harness bar has made my car a little stiffer. Especially when the top is removed. I also had my car aligned after I installed the bar. It mounts (4 points) to the upper and lower seatbelt mounts and is very well engineered and easy to install. You have to purchase the lap mounts and sub bar if you want at least a 5 point harness. This setup does work with the stock seats and you can add a race seat later if desired. Unfortunately I don't have any pictures. As far as what you need depends on how safe you want to be. I got a harness bar because my wife was concerned for my safety. While I was buying it I got a six point harness, extinguisher mount, and camera mount (to help data log of course).
Old Nov 28, 2012 | 08:31 PM
helphos's Avatar
helphos
Default Harness Bar
When I bought my 93 vert, it had the roll bar already installed. It's always felt reasonably stiff, but it has the Xbrace underneath like all the convertibles.
I doubt that the roll bar adds much to the stiffness, but since I didn't have to pay for it, I like it. I have a five point harness that works with the roll bar that I use for track days.
Good luck!
Old Nov 29, 2012 | 03:33 PM
mxnuke's Avatar
mxnuke
Thanks to all for your input.Car goes for a cam change around the 2ed week in january,got a solid .580 roller to replace the hyd roller in car now.After that change and tune i will look into a 4-6 pt bar. I just sold a race car with a full cage and i hated all those bars,heres a pic to show you what i mean..thanks..Dennis
Old Nov 29, 2012 | 09:10 PM
l98tpi's Avatar
l98tpi
Max G’s
I have one just like this one below;
http://www.racingjunk.com/Other/2738...rness-Bar.html
I removed it to install a roll bar per class rules. You can have it for $100 if you want to come to Monroe, OH and get it.
Old Nov 29, 2012 | 09:15 PM
Grandsportfan78's Avatar
Grandsportfan78
If he doesnt want it, would you ship?
I would take it
Old Nov 29, 2012 | 09:44 PM
KentsOkay's Avatar
KentsOkay
Anyone have advice on what bar/straps to buy?
Old Nov 29, 2012 | 10:41 PM
mxnuke's Avatar
mxnuke
Thanks for the offer [ l98tpi ] but i got an e-mail today about esta rules and im going to need a roll bar. Who in ohio put your roll bar in if i may ask? thanks.Dennis
To harness bar?
