1987 Trans question
Old Nov 28, 2012 | 08:36 PM
Blown1987's Avatar
Blown1987
Default 1987 Trans question
Sorry if this sounds dumb, my tranny has burnt up I'm weighing out my options and came across a cheap rebuilt one from an 89 Camaro are all the 700r4 the same?
Old Nov 28, 2012 | 08:48 PM
vetteoz's Avatar
vetteoz
Yes and no
All T700's are physically the same
Vette trans has different programming ( valve body and governor ) for shift points.
Vette trans has a special , shorter tailshaft housing to mount the C Beam so you would have to swap that over
to the new trans and most have then had to cut 3/4" off the output shaft because that is too long with the shorter housing
Old Nov 28, 2012 | 09:02 PM
C409's Avatar
C409
........... Your sig is Blown1987 ... if your combo does indeed include forced induction a stock trans will be at a distinct disadvantage life expectancy-wise ... much like the wounded trans in your car now ..... the 700R4 is a sturdy , reliable trans much like a Dana 36 rear ... most will survive the average driver in an average vehicle ... but few will live through real abuse without special attention and some expensive parts ..........
Old Nov 29, 2012 | 07:06 PM
Blown1987's Avatar
Blown1987
Thank you, guess I'm just gonna have it rebuilt with upgraded parts and a shift kit. It does have a procharger and a few other mods but its my show car i rarely abuse or get on the car. Clutch packs went because of the tv cable not adjusted correctly.
Old Dec 1, 2012 | 11:32 AM
pricesgarage's Avatar
pricesgarage
were are located im in wva i have a transmission shop 304 203 0183
To 1987 Trans question
