Rearend Shifting
So my question is; When I shift gears, or accelerate/decellerate, the rearend shifts side to side. Its not bad, and it does get worse with the top off (obviously). Now I'm not sure if this is a normal charactoristics of the car, or if its bushings or what. Any help, or input would be greatly appreciated. Peace. h
For percise answers were going to need your information, such as the year, model and transmission(auto, 4+3 or 6 speed) and mileage!
I can tell you that a shifting rearend is not normal! Could be the bushings or u-joints, have you looked under there? Vette rearends have alot going under there!
Oh and we love to see pictures of your new ride when you get a chance!
under acceleration it would drive the wheel out, steering back of the car to the center line. decell and would steer back to ditch.
check the toe links on the back of the bat wing diff cover assembly asap. the tie rod attaches to the rear hub, much the same as a front hub. if the tie rod ends wear or get loose, does just what you describe.
Thanks Bro! h
Sorry for leaving out some tech! Duh! Its an 84, with a 4+3. Wish it was a 6 speed, Lol. And am really considering an LS swap, with a 5, or 6 speed. Whichever one is mostly a bolt in. She just turned over 120,000 miles a couple days ago.
I have been under it to replace the mufflers, (so loud the dash rattled) but really just did a visual inspection, (leaks, and such) but did get up close and personal. I am planning on going through the whole thing as funds allow, but I dont want to drive it, and hurt it either.
Really I dont have to nail it. Say 25 in 2nd, and not even aggressively, get on, and off the throttle, and you get a bit of rear steer. I have nailed it a couple times, and she gets a bit sideways, but as I said earlier, before I know whats going on, Ive been taking it easy on her. Thanks for the reply though! h
http://s1310.beta.photobucket.com/us...rvette%20Monte
BTW, welcome to my world !
You need to go to fleabay and find a set of used FSM books if you want to survive owning a Vette...
Next,. the rear toe assy is delicate. The inner are just ball & socket,non-adjustable non-servicable.
The outer is typical tie rod end. That end is slipping up/down in the knuckle mount. Thats what the wiggle is when you step on the gas....and a shift the other way when you let off the gas...
Get this looked at ASAP . Its dangerous ! You haven't seen ugly until you've seen a vette rear end take a hard right turn at 60 from a broken tie rod...
Test the rods...
Take the ends out of the knuckle. Lift the rod up. It SHOULD stay up if the ball & socket inner rod assy is ok. If its loose, and falls, it must be relaced. The rods DO come out of the plastic socket. Non-servicable. Shop FleaBay for some used rear toe assys...as long as the rod is semi stiff in the socket it is ok for street use.
The outer...if the tie rod end is worn out the stud is damaged ......thats where your slack comes from,. the stud walking up/down as the torque of the rear wheel pulls on the toe rod assy. Let off it goes down...car goes right...step on the gas the stud goes up car goes left.Try to tighten the crown nut as much as possible. Otherwise its just worn out. Watch that inner rod assy...if its loose dont mess around.
Test the rods...
And much, much, more in an attempt to resolve the problem.
The final solution was the toe setting.
But before any alignments are accomplished, the mechanicals must be tight.
