Car will not start Update.
Old Jun 8, 2002 | 07:46 PM
dans86's Avatar
dans86
Default Car will not start Update.
I jumpered the neutral switch and she fired right up. No clutch still though :mad I'm going to try bleeding the system again ( I don't think I did a very good job, Pedal's mushy). I can't believe I need a new clutch after 27k easy miles. Thanks for the Help :) :)
Old Jun 8, 2002 | 07:52 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: Car will not start Update. (dans86)
You mean the clutch switch?
It's no day at the beach bleeding the clutch system. Phoenix injector helps a lot on the ZF, not sure with yours. Some of the 4+3 guys can probably help a lot more than I. Did you disconnect the slave and raise it as high as possible?
Old Jun 8, 2002 | 07:56 PM
dans86's Avatar
dans86
Neutral Safety Switch. Behind the Pedal. Not a whole lot of room down there. I put a hose over the bleeder and ran it into a cup. I then proceeded to knock the cup over. What a mess
[Modified by dans86, 5:59 PM 6/8/2002]
Old Jun 8, 2002 | 08:06 PM
PeteL's Avatar
PeteL
Sounds like a normal afternoon in my (1/2) driveway.
BTW, any idea how to get PS fluid off of blacktop? :rolleyes:
Old Jun 9, 2002 | 01:22 AM
jfb's Avatar
jfb
Default Re: Car will not start Update. (PeteL)
PeteL, if you don't have a cat, buy some cheap clay kitty litter and sprinkle it on the spill. I also grind it into the spill with an old pair of shoes. Next day sweep it up and pitch.
To Car will not start Update.
