C4 modifications?
Old Nov 30, 2012 | 11:07 PM
Hipsterdoofus's Avatar
Hipsterdoofus
Default C4 modifications?
What is the single most valuable performance modification that you can do to a 1995 LT1 corvette...I have been aimlessly searching for an answer for a half hour...
Please advise....chip...exhaust...mod? what?
I have topped my c4 out 2 times and it has stopped on 155 is this because of a GM computer setting?
Old Nov 30, 2012 | 11:25 PM
slickfx3's Avatar
slickfx3
airfoil
Old Nov 30, 2012 | 11:29 PM
cv67's Avatar
cv67
St. Jude Donor '05
Driver mod
Remove that part of the brain that pushes us to spend every last dime on these damn things lol
Old Dec 1, 2012 | 12:14 AM
fc_soldier's Avatar
fc_soldier
Torque Converter if its an auto and/or a rear gears will wake it up.
Old Dec 1, 2012 | 01:07 AM
vetteoz's Avatar
vetteoz
What is your driving style / use of the car?
Because the engine won't pull the car any faster
What revs / gear were you in?
Old Dec 1, 2012 | 01:18 AM
Blown1987's Avatar
Blown1987
May i ask why you wanna go faster then 155mph?
Old Dec 1, 2012 | 02:02 AM
Hipsterdoofus
Rhetorical questions are not relative in this situation
Pfffffftttttttttt....................... ........
Old Dec 1, 2012 | 02:13 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Swap the driver side from left to the right side, Euro lights, fill tires with nitrogen, Octane Booster, Dexcool, tornado, and new floor mats.
Old Dec 1, 2012 | 04:29 AM
lt4obsesses's Avatar
lt4obsesses
Depends on what exactly you want from the car, and how you use it the most.
Do you want to go faster? Quicker? Handle better? Louder?
I've not heard of a governer on the Corvette's and I believe the LT1 cars were once tested by one of the car mags with a top of around 162 or such. Read it along time ago, so...
But there is no one magic trick for noticeable gains. It is when a variety of mods are done that compliment eachother, that the real seat of the pants results are found. Like cam+rockers/heads+exhaust. Each one, alone may give a little more, but it's when these things are planned out to work in concert, that the goal is achieved.
So, what you are really asking, is "where do I start?"
Old Dec 1, 2012 | 06:51 AM
WW7's Avatar
WW7
Well Doofus, It won't go any faster because you don't have a
...................... "Rear Wing".....WW
Old Dec 1, 2012 | 07:54 AM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
Regular preventive maintenance...
Replacing 20 year old plugs, injectors, wires, ICM, coil, MAP.... etc.
Old Dec 1, 2012 | 08:55 AM
AirForceOne!'s Avatar
AirForceOne!
You asked for it!
Old Dec 1, 2012 | 09:38 AM
dizwiz24's Avatar
dizwiz24
In your case, its going to be replacing your optispark.
A bad optispark will cause the engine to bog down under load in high gear. (Uphills, with the wind resistance of a top speed run, etc.)
When mine was bad I would hit say.... 115 MPH and then it would feel like you just hit a brick wall. It would not go any faster.
Old Dec 1, 2012 | 09:40 AM
dizwiz24's Avatar
dizwiz24
To answer your question,
there is no 'single mod' that is going to provide you a noticeable improvement.
I would say heads/ cam / tune / long tube headers...is what you want to do. I did these all at once (made 353 rwhp/ 355 rwtq) and felt a difference in top end pull.
IMHO... dont waste money on the exhaust. its already a free-flowing setup.
Old Dec 1, 2012 | 09:59 AM
c4cruiser's Avatar
c4cruiser
Maybe the question should be what do you want the car to do? HPDE events? Drag racing? Autocross? The type of event you want to do can make a difference in the type of engine mods that will help the best.
As far as a top speed, 155 is not that bad depending on the trans and diff gear ratio. And I assume you are talking about hitting these speeds on a closed course Talking about driving at high speeds on the street may wind up having a Mod locking your threads.
So what is the car configuration? Auto trans coupe? Manual trans car? A manual trans C4 will make its top speed in 5th gear, not in 6th. For either trans, you can expect a top speed in the 155-160 range as that was the speeds that various car mags came up with when the tested the later C4's when they were new.
Old Dec 1, 2012 | 10:34 AM
dizwiz24's Avatar
dizwiz24
not according to motor trend march 1992? (somewhere around that date). There was an RX-7, 300ZX and 3000GT VR-4 ( i think?) 4 car comparison. I think they also threw the acura nsx in there for the top speed challenge.
The 1992 c4 lt1 6spd ran 172 MPH in perfect conditions (no winds, flat desert road, low altitude) conditions. Averaged out 2 ways to cancel any minor effect of wind or grade. No, this is not the zr-1, but the lt-1 that ran that speed.
Though I will agree on certain conditions (headwind, grade of the road, altitude, etc.) could make 155 the top speed
Old Dec 1, 2012 | 11:18 AM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Buy a C5 or C6.
To C4 modifications?
Old Dec 1, 2012 | 12:29 PM
dizwiz24's Avatar
dizwiz24
Originally Posted by TorchRedlt4man
Buy a C5 or C6.
Ill have to either agree or disagree with torchredlt4man depending on your answer to this next question:
Do you have a garage, tools, knowledge, service manuals, know-how to turn a wrench on this car?
If the answer is 'no', then torch's advice is pretty good.
Now, if the answer is 'yes'... then prepare to spend lots of money and invest lots of time (more time/money than you would to soup up a c5/6) to make the c4 run. Also plan on lots of downtime (time not driving the car). C4 mod's take time, patience. Not plug-n-play solutions. Rather 'find this guy and get him to weld/mod this part', 'find another guy who knows how to do this'.
Im just in it to prove a point. I will spend lots of money to do so. In the end, will probably be a slightly slower car than a similarly mod'd c5/6 that someone spent less money (than me) to mod and more time enjoying their car by driving it.
However, I like the c4 just that much more than the c5/6. Or maybe its the owners.
C5/6 guys Ive met seem to snicker and look down at me (as a c4 guy). I dont get on off-topic anymore as I got tired of people (who disagreed with a non-car viewpoint of mine) would look into my profile and bring up the fact that I have a c4. Its irrelevant. Those people SUCK.
Its reasons like this that I continue to mod the c4.
Old Dec 1, 2012 | 12:36 PM
cv67's Avatar
cv67
St. Jude Donor '05
I would not count on anything being wrong wiht your car not doing 170 stock lol. 155, probably just fine for a 25+ yr old car. Cant believe everything you read.
Old Dec 1, 2012 | 12:45 PM
TorchRedlt4man
Whoa!
Just kidding, guys!
I have had three (3) C4s. All new. I only sold the previous one to buy the next one.
In January '96, there was as much or more secrecy concerning the all new C5. I thought I would buy a 96 CE and wait to see if I liked the C5 enough to move up in a year or two.
Still waiting..............
I did like the C6 a little more.
BUT, there is NOTHING to compare sitting in the "Fighter Cockpit" of a C4!
Ordered my CE w/LT4 in March '96. I picked up my Vette up in April '96. I did my first mod in June. Oh well, I guess I do not qualify for NCRS!
There are so many tricks and mods that can be done to ANY C4. Some do more than others as far as HP and/for torque. There is also the question of customizing the interior/exterior.
The list goes on and on..........
Did I mention I really LOVE C4s?
