injectors
Old Dec 9, 2012 | 03:13 PM
underpar67's Avatar
underpar67
2nd Gear
Default injectors
My 89 is idling up and down and very unstable. It has 37 k and is completely stock, im going to replace injectors and was wondering whats the best ones out there to buy?
Old Dec 9, 2012 | 05:01 PM
AirForceOne!'s Avatar
AirForceOne!
Have you tested your injectors? There are alot of things that can cause your idle to be off.
The PO replaced my injectors before I got it, but when I'm ready to replace them, I will probably go with these.
http://www.ecklerscorvette.com/corve...1985-1996.html
Old Dec 9, 2012 | 05:08 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Jon, who owns Fuel Injector Connection, will be able to answer all of your questions.
Search FIC here and you will see tons of threads.
http://www.fuelinjectorconnection.com/
If you have some time, you can read about my personal/business experience with Jon here:
http://forums.corvetteforum.com/c4-t...long-read.html
Old Dec 9, 2012 | 05:12 PM
leesvet's Avatar
leesvet
Why throw parts when there are a multitude of other things to be checked first?
ever look at the IAC? Idle Air Control?
vac leaks?
TPS?
EGR?
all of which can cause unstable idle. You don't have the miles to justify tossing injectors....age, yes, miles, no. Look into other things before wasting time and money and the risk of creating other problems.
When it comes time,. Call Jon.....@ FIC look on YouTube under fuel injector.
Old Dec 9, 2012 | 06:10 PM
l98tpi's Avatar
l98tpi
Max G’s
vac leaks?
TPS?
EGR?
Look at the IDle Air Control (IAC) valve first.
Old Dec 9, 2012 | 06:49 PM
underpar67's Avatar
underpar67
2nd Gear
Yea i agree with that but there are no trouble codes and from what i here the stock injectors are not very good to begin with.
Old Dec 9, 2012 | 06:58 PM
black88z51's Avatar
black88z51
I'm changing my originals right now. I went with bosh III @ 22lbs after reading that they were a good replacement to stock. If yours are original then probably time to change. That rough idle could be any one of a number of things including your throttle body is leaking, plus what the guys mentioned above.
Old Dec 9, 2012 | 07:24 PM
gunnerjuju's Avatar
gunnerjuju
One more vote for IAC check b4 replacing anything.
Old Dec 10, 2012 | 12:32 AM
Cliff Harris's Avatar
Cliff Harris
That's a vacuum leak about 99% of the time.
Originally Posted by AirForceOne!
I don't know if it's still true, but Accel injectors used to be repackaged Ford Motorsports injectors.
I recommend Jon at FIC. The best customer service you will ever find. VERY knowledgeable and will bend over backwards to make you happy. That's what I have in my car.
To injectors
