94 running hot
Old Dec 9, 2012 | 11:28 PM
matt_jahn's Avatar
matt_jahn
Default 94 running hot
My friend has a 94 auto. Stock as far as I know. In the summer when he first got it I immediately noticed it ran st about 188. Where my 92 manual runs about 214. I though maybe he had a 160 t stat or something.
But the problem, he came to me today saying it got to 260, analog gauge. So I watched it warm up to 223 and no cooling fan so I got nervous and shut it off. With a tech two I can command the fans in, the water pump has good flow at the reservoir. It was 44 degrees today.
It only gets hot sitting still. So what I'm waning to know is what you think, what temp the fans should come on, and the part number for a 160 t stat incase it needs one?
Old Dec 10, 2012 | 12:28 PM
lt4obsesses's Avatar
lt4obsesses
I'm not sure about '92 or '94's, but in my '96 I have a primary and secondary fan. The primary comes on at 228* and the secondary at 230*. That said, on the hottest of days, it will get to 231* tops and start cooling off in city driving. I run a 180 t-stat and cruising I'm consistantly between 185 and 188 on the highway. The analog will always look hotter than the digital and the digital is the more correct of the two. a 180 t-stat is more than sufficient for these engines.
Old Dec 10, 2012 | 10:20 PM
93Rubie's Avatar
93Rubie
Primary fan isn't on till 228. Stock t-stat is 180. Sounds like it is just fine.
The gauges are NOT linear devices. Use the digital for accuracy.
Yours may run hotter do to junk build up in system, crap on radiator/condenser, old coolant, worn water pump, etc....
Old Dec 12, 2012 | 06:57 PM
jimyz's Avatar
jimyz
I have 94 reprogrammed by pcmforless. The pri comes on@185, sec@190-195. I have a 160 stat. My car never goes above 190 in stopped traffic. Before the mods, I would see 230-240 in traffic. It works, no codes or problems. Cost was around 200-250$
Old Dec 13, 2012 | 05:40 PM
tbirdsps's Avatar
tbirdsps
I had the same problem with my 90. The radiator was all clogged up now it barely reaches 220 in stop and go traffic at over 100 degrees. Over 20 years of crap that the POs never cleaned out. I haven't heard the fans in over 6 months.
Old Dec 15, 2012 | 01:24 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
1994 LT1 - based on digital dash coolant temps -- primary fan on at 228, off at 218, secondary fan (passenger side) on at 235, off at 225 (+/-). Based on A/C, primary fan on immediatly, and passenger side on if A/C manifold high-side pressure exceeds 235 (typical if air temps above 90).
assuming the thermostat has not failed mechanically, the analog gauge temps do align with the digital temps, albeit the analog is typically about 10 degrees warmer throughout the range.
The thermostat can fail mechanically in that the lower portion of the thermostat which controls the recirculation of coolant within the engine
can separate from the upper (normal) part of the thermostat (happened to me on 94). This does cause a much larger difference between the digital and analog guages.
Generally 94 should run at 194-197 while driving, but can go to 230 at a long light -- unless turn on the A/C (which most of us do).
btw, your 92 sounds like IT is running too hot, suggest checking between radiator and A/C Condensor and in front of A/C Condensor. If clean, you should have the LT1 engine and thereby the 180 thermostat, suggest replacing your thermostat (e.g. ACDelco 131-100).
To 94 running hot
