C Beam help!
Old Dec 13, 2012 | 04:12 PM
Blown1987's Avatar
Blown1987
Default C Beam help!
For the life of me i can't get the back bolts to even break loose. I put some pb blaster on it and I'm gonna try torching it tonight . Anyone have any idea how to put a wrench on the front two nuts? Doesn't seem like its possible to get anything on them to tight of a fit and fat hands Any advice would be appreciated!
Old Dec 13, 2012 | 04:20 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
If you'r talking of the nuts on the top it just takes patience to get a wrench up there to keep them from turning.
Old Dec 13, 2012 | 04:28 PM
383vett's Avatar
383vett
A 21mm open ended wrench will rest on the cbeam and hold the nut. It helps to have an air wrench, but you still should be able to loosen the lower 21mm headed bolt with a 1/2 rachet or breaker bar. They are torqued to 65 ft/lbs. Fat hands definitely make it tough.
Old Dec 13, 2012 | 04:36 PM
Blown1987's Avatar
Blown1987
Thanks, that's what i needed to know.
Old Dec 13, 2012 | 06:21 PM
383vett's Avatar
383vett
Oh, forgot to add, when you start turning the bolt on the underside, the nut on top will turn. The wrench will wedge against the tunnel and stop the nut from turning. Good luck.
Old Dec 13, 2012 | 06:32 PM
cumbercr's Avatar
cumbercr
Once you get the bolts out the wrestling match to get the C beam out begins. It can be frustrating and require much swearing, but it does come out. I reinstalled mine with C beam plates. They make it much easier to torque the bolts and I did notice an improvement in my launch.
Old Dec 14, 2012 | 02:08 PM
DanZ51's Avatar
DanZ51
Relax, once you do it 3, 4, 10 times it becomes much easier
Old Dec 14, 2012 | 02:37 PM
ch@0s's Avatar
ch@0s
In my experience the C beam and drive shaft kinda have to go in together then tighten it up. It you try one at a time you cant get them in.
Old Dec 14, 2012 | 03:47 PM
383vett's Avatar
383vett
Try 20, 25, 30 times. After a while, I had mine velcroed in.
Old Dec 14, 2012 | 08:30 PM
mtwoolford's Avatar
mtwoolford
Originally Posted by Blown1987
For the life of me i can't get the back bolts to even break loose. I put some pb blaster on it and I'm gonna try torching it tonight . Any advice would be appreciated!
NO! NO! Mister Bill! no hot work on or near fiberglass!
some patience and a wrench will fit on the nuts atop the c-beam; you may have to experiment with some wrenches of different overall lengths to find one that gets up there, but trust me, it can be done.
use a six sided socket / breaker bar combo on the head of the bolt.
Old Dec 14, 2012 | 09:09 PM
Blown1987's Avatar
Blown1987
I don't believe the trans has ever been taken out. I've been trying for 2 days an pb blaster and it won't budge. I have a 21mm socket and 1/2 ratchet and using a breaker bar and all my weight and nothing. I don't know what else to do or try.
Old Dec 14, 2012 | 09:45 PM
ch@0s's Avatar
ch@0s
Do you have a friend with an impact? It may be time to go get one.
Old Dec 15, 2012 | 12:01 AM
Blown1987's Avatar
Blown1987
Ah just about got it had to take the handle to my floor jack and use it as it as a handle extension lol. Any tips for the next step of dropping the Trans?
Old Dec 15, 2012 | 05:13 AM
fc_soldier's Avatar
fc_soldier
If this situation trying putting a jack under the rear and jack it up. It will change the angle and reduce the bolt binding going in. It should slide right in.
Old Dec 15, 2012 | 05:24 AM
fc_soldier's Avatar
fc_soldier
Have a lot of extensions and make sure to take note of grounds.
Old Dec 15, 2012 | 09:45 AM
cumbercr's Avatar
cumbercr
Once you have the C beam bolts broken loose, place a floor jack under the transmission and raise it slightly until you can slip the C beam bolts out. Then wrestle the C beam out. To get at the transmission bolts lower the transmission. Be careful not to break the wiper controller. With the transmission lowered you should be able to get to all 6 bolts from below with a long extension and a 9/16 socket and a flex adapter.
Old Dec 15, 2012 | 11:04 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Craig - what are C-Beam plates ? Do you have a photo you can post for us? Where did you purchase yours ?
To C Beam help!
Old Dec 15, 2012 | 03:06 PM
cumbercr's Avatar
cumbercr
The plates are stiffeners. I don't have pictures but you can view them at www.ZFDoc.com. The plates that go on the top of the C beam are basically nut plates. The beauty is that you don't need a wrench on the top nuts when torqueing. They are supposed to stiffen the C beam and prevent the rear from kicking out to the right when you launch. Some say they make no difference. But my experience is that they did help. My 85 now launches in a straight line. They are a bit pricey. But someone with welding skills could make them pretty easily.
Old Dec 15, 2012 | 03:40 PM
Blown1987's Avatar
Blown1987
Thanks guys I really appreciate all the quick advice and help. What do you mean by take note of the grounds? What grounds?
Old Dec 15, 2012 | 05:07 PM
illenema's Avatar
illenema
Impact time
