Opti Spark: Typical Failure Mode
Old Dec 14, 2012 | 03:42 PM
KJL's Avatar
KJL
Default Opti Spark: Typical Failure Mode
When these units fail I assume it is because of the optical sensor going bad? I just pulled mine and it is clean on the inside with the exception that one of the rotor screws had fallen off. The car has 46,000 miles on it and is a 96. I would like to just clean up the rotor and cap electrodes with ah little sand paper, stick the rotor screws back in with thread sealer, replace the shaft o-rings and call it a day.
Old Dec 14, 2012 | 03:46 PM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
I would do the same.
Old Dec 14, 2012 | 05:31 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Your '96 factory Opti should still have lots of miles left in it.
My '96 has just over 119,000 miles on the factory original Opti, and running just fine.
Old Dec 14, 2012 | 05:40 PM
Phat98's Avatar
Phat98
Mine just rolled over 116K, no probs yet...but careful with that "sandpaper", I hope you're using some fine paper or emery cloth. Any scrapes or gouges you put into the rotor or cap will only accelerate them wearing out.
Most people would tell you just throw another cap and rotor on it while you have it out...those would be the folks that never priced an Opti cap and rotor set.
Old Dec 14, 2012 | 07:40 PM
oilyfishhead's Avatar
oilyfishhead
The one in my '96 Impala SS has 247K on it and has never been serviced.
The one in my '94 vette crapped out with a bad bearing at 138K. that was about 3K after I changed the cap and rotor ( which was about to come apart).
Old Dec 14, 2012 | 10:11 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
http://www.youtube.com/watch?feature...&v=lFCjaz6zHfc
Old Dec 15, 2012 | 10:23 AM
KJL's Avatar
KJL
Thanks guys, yes just knocking the carbon of the studs and rotor with some 600 grit wet/dry paper.
To Opti Spark: Typical Failure Mode
