door panel removal drivers side
Old Dec 17, 2012 | 07:41 AM
joebuckSR's Avatar
joebuckSR
Default door panel removal drivers side
Is there anyone that can give me a detail of how to remove the drivers side door panel?
Old Dec 17, 2012 | 08:32 AM
94z07fx3's Avatar
94z07fx3
The details vary by model year. Which year are you working on?
Old Dec 17, 2012 | 09:55 AM
joebuckSR's Avatar
joebuckSR
sorry 1995 coupe
Old Dec 17, 2012 | 10:15 AM
94z07fx3's Avatar
94z07fx3
The bottom is held by vinyl plugs that can be pried out with little effort. The area around the door handle is where you will find a lot of screws.
Two will be down in the hole you grab to close the door.
One is just in front of the unlatch lever.
One is behind the lock lever. Just unlock the door and pull the plastic lever off the rod and you will see the screw behind it.
Then there is one screw under the lens for the lamp you will see if you pop off the lens.
You can lift the door panel off with two hands and reach around with a thrid hand and undo the connectors for the power windows, door lock, and mirror OR you can unsnap those plastic bezels from the door panel and twist them a bit and push them through the door panel so that they stay connected to the wire harness and the door panel lifts off without them.
Old Dec 21, 2012 | 08:53 AM
LannyL81's Avatar
LannyL81
Lower door glass all the way down
Remove plastic plugs along door bottom. Best to either buy the tool or make one to avoid destroying these plugs as most are not available.
Remove two screws in door pull.
Remove door pull / window / mirrow controls....remove connectors.
Use small blade screwdriver to pop-out door light, about 1/2" in from each end.
Pop-off door lock know by prying with screwdriver on thick end.
Remove screw behind door light.
Remove screw in middle of door trim panel.
Remove screw behind door lock ****.
Remove door trim panel. A bit tricky, take your time.
Lift door panel up and then away from door but only about 2".
Disconnect electrical connector going to hatch release.
Door panel is free from car.
Now, why are you removing the door panel?
Old Dec 25, 2012 | 10:02 AM
joebuckSR's Avatar
joebuckSR
The window glass is hitting the roof panel when shutting the door. Fixed it , there is a plastic guide that bolts onto the window that broke.
To door panel removal drivers side
