tuner needed 86 with mods
Old Dec 17, 2012 | 01:50 PM
alaskagordon's Avatar
alaskagordon
Default tuner needed 86 with mods
Hi guys
I really could use some help with a custom chip. haven't been able to find anyone here in colo to tune for me.
what I have is an 86 ,auto trans with
trick flo super 23 deg 195 aluminum heads
Comp Cams CS 280XFI HR-13 hyd roller cam with retro fit lifter kit
ACCEL big mouth intake base
SLE (siamesed) runners #SLE20002
port matched to stock plenum
fuel pressure reg & new injectors 24 lb/hr
was planning a 383 stroker kit but ran out of money.
It runs really good when cold (open loop) then just ok once it warms up
big lag when accelerating till it reaches about 2800
cuts out while cruising ,set TPS volts down to .485v & that helped eliminate most of cutting out. seems when running at part throttle something is shutting off injectors for a split second then back on.
seems to be running rich sooty black exhaust pipes.
need VATS bypassed & would like fan on at 180-190 deg
I have moates chip adapter, cable, & data logs from tuner pro
datamaster 8D V351
also have 3 chips & hypertech chip in it now
not sure how to attach data log to send
please let me know if you can help & cost.
Thanks alot
