1986 high idle
Old Dec 19, 2012 | 10:12 PM
knuckles80's Avatar
knuckles80
Cruising
Default 1986 high idle
The car had a very high and surging idle.replaced the injectors, replaced some old brittle vac lines, and this made the car run and idle much better but instead of the 1200 rpm idle it still idles at 900. replaced plugs and wires, fuel pressure is in check, replaced iac valve and set idle to 550 per Haynes manual. After setting the idle it "stuck" and I thought it was fixed. But after the initial idle set, once it is restarted after a drive it goes right back to 900. The tps has been repeatedly set to .54 after every idle reset. Any ideas?
Old Dec 20, 2012 | 02:16 AM
Cliff Harris's Avatar
Cliff Harris
A high idle is almost always a vacuum leak. Try removing and plugging all the vacuum connections to the plenum. That includes the brake booster, the two fittings on the rear passenger side and the one under the throttle body. I had a vacuum leak at the hose where the PCV valve tube attaches to the intake manifold.
Another possibility is an EGR valve that's stuck open.
It's also possible that the ECM is seeing low coolant temperature and you're in "fast idle" mode. Check the CTS (Coolant Temperature Sensor) on the front of the intake manifold under the throttle body. They're pretty cheap, so it might be easiest to just replace it.
A scan tool will tell you what the ECM is seeing and might help you determine what the problem is.
Old Dec 21, 2012 | 09:08 PM
black88z51's Avatar
black88z51
Is your throttle body leaking??
Old Dec 22, 2012 | 09:13 AM
C409's Avatar
C409
........ The Haynes manuals are helpful ... sometimes ... but a Factory Service Manual from Helms is worth its weight in gold ... you can find them on the parts for sale forum from time to time ... get one ... you'll be glad you did ..............
To 1986 high idle
