....... Check for raw fuel in the vacuum hose that runs from the rear of the plenum to the fuel pressure regulator ... sounds like you might have a ruptured FPR diaphragm ............ As far as the PROM's are concerned ... the car will start and run just fine as long as the PROM itself is for a 1990 code ... the gear ratio wouldn't change the fueling maps much at all ... and the only function of the transmission that's controlled by the ECM is the timing / road speed at which the converter clutch locks up ..........
So what you are saying is that the prom does NOT control shift points?
Fuel Pressure Regulator..I'll check it today.
FPR is a good check! Don't worry about anything except a Corvette '90MY PROM -
You might add a location to your profile.
There's likely someone in the vicinity that might offer up some assistance. Might even have a PROM you could try. You're way to concerned about the code! Your car IS NOT the only car with the code, a vert it was the base ratio and PROM but a base coupe with the same axle ratio is the same code PROM also. Again - you're way to concerned with the PROM ID! MY OPINION!!
I DON"T have the OEM Chip to begin with. I don't know if it's possible to put a NON-OEM chip on a NON-OEM chip or even if the chip I have is the correct gear ratio etc.
Post 8 gives you a step by step solution if you don't have access to an ANHW prom. Just use an ANHT & modify the shift points in the bin if you find it necessary.
Using a prom burner/reader, you read and download the calibration FROM your current chip. If it works currently, unless you tap it, You should be able to use it. I doubt they changed anything from stock except maybe some timing or additional fuel top end. For those you probably could compare to an ANHT bin file. the VE and SA tables are probably identical.
Once you have read the current chip, you could make changes to it using an editor like TunerPro 5.0. Then just flash a new memcal. Voila!
If some if this is confusing, suggest you go to thirdgen.org and read the stickies in the DIY-Prom forum.
Sorry guys. I didn't realize that I (as in at home) could make changes to a prom myself.
I think I get it. Download an ANHT or whatever prom for a 90 model. Then I can change that info to a 2.73 gear if necessary?
All of this computer stuff is very new to me. And this Corvette stuff is even newer.
I was under the impression that I had to have the EXACT .bin or memcal or whatever before I could burn it to a new prom.
That helps a lot. I was getting pretty aggravated with the fact that GM would just quit making the one thing that without it the car is DOA.
Oh and the Fuel Pressure Regulator is good. But I am thinking that it may have a weak coil or be getting a really weak spark. The GM HEI is one thing I am familiar with from my Camaro days.
I found a bin for a 91 5.7 Auto 2.73. AXCS. IS there a free program I can use to open the .bin and look at it to compare it to the ANHW.
Would the 91 work in the 90. Both are speed density cars.
Call these guys and they can hopefully get you up and running!
I installed a TPI 350 V8 in my Jeep Wrangler. The TPI was from a 305 IROC Z from 1987. Street and Performance hooked me up with a harness and computer with a chip set up for all my specs. I currently run a Corvette computer with a MAP system. Changed over from the MAF system. I can't imagine them not being able to provide you with an appropriate chip. Good Luck.
Does the 91 use a 7727 ECM? If so, then it should be using an $8D mask for the bin definition file. And so they could be compared. I looked through some of my files and found a hac of the ANHT code. I'll look through it to see if there's anyplace that would pertain to rear axle. If the 91 is the same def file, then just use the values in that bin and make the change to modify it into an ANHW.
Again, I would try reading the chip you currently have and do a compare to an ANHT bin. You will need a chip reader/burner to download the calibration and then burn a new one.
I have a .bin for an AXCS. It's a 91 5.7 Auto 2.73. The 91 uses the 7727.
My understanding is that the speedo is controlled by the speed sensor located on the transmission and NOT through the ECM. So why is the gear ratio even a factor in the prom? Does the ecm take shift points from the Speed Sensor?
Should I get an ALDL cable or a chip reader/burner?
Has anyone ever heard of Cardone? A friend at the local Autozone claims he can order the ANHW or any other prom from Cardone for $70.00.
I told him to go for it and see what happens. He put in the numbers and now we have to wait to see if it is rejected. That's the first time I have ever heard of that from Autozone.
you can find most of GM file .bin, i've searched for you and i find the ANTH 90 vette auto with 3.07 rear end,or the 91 AXCS vette auto with 2.73 rear end,you can burn these file on a 27C256 type eprom using an eprom programmer...
Sorry for the delayed response. Autozone is having no luck ordering from Cardone. Everytime they put in the number it is rejected in a couple of days.
Tunedport85inject: I appreciate that info. I was in the process of ordering the programmer and wasn't sure what chip to burn the .bin onto.
I am going to try the AXCS and see how that works out. I've got a little time as we have pulled the x-brace and entire exhaust out from under the car to do some work on it.
you can also call PCMforless ,the guys there can give you lot of info and a base tune for your MY,but you can also post on the SCAN & TUNE section of the forum
if you want to burn an eprom by yourself using a programmer the type eprom is a 27C256.Go to the Moates site for more info,there are also other type of prom you can use...
