85 MAF replacement
Old Dec 28, 2012 | 10:22 AM
LongBeachC4's Avatar
LongBeachC4
Default 85 MAF replacement
Back a few months ago I pulled the MAF and cleaned it with MAF cleaner, screen was dirty. Ever since I have had a high 900 to 1200 rpm idle until it goes into closed loop after warm up, then it seems fine. I bought a remanufactered MAF last night. Got home, and installed it only to find the car will start but not idle, it just dies. I swapped back to the old unit and it's running fine. Does anyone know if you have to do anything to reset the computer when you do a MAF change.
Old Dec 28, 2012 | 10:53 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
No reset needed, about all I can suggest is to check your connector. Be sure all the pins are connecting correctly and that they are clean. I'm sure someone will chime in with a better suggestion, I have never encountered this.
cumbercr's Avatar
cumbercr
I would try disconnecting the battery to dump the memory in the ECM.
Old Dec 28, 2012 | 11:17 AM
Muffin's Avatar
Muffin
Why would you do that? The MAF feeds the ECM a voltage, Zeroing out the ECM will clear any codes, wonder what ther are, and wipe out short term fuel trim.
LongBeach are you getting a Check Engine light?
Old Dec 28, 2012 | 11:46 AM
cumbercr's Avatar
cumbercr
I'm assuming the fuel trim has been adapting to the old MAF. The same approach is used when replacing injectors.
Old Dec 28, 2012 | 03:59 PM
LongBeachC4
No codes or check lights coming on
Old Dec 28, 2012 | 04:47 PM
cumbercr's Avatar
cumbercr
Do you have a scanner? If so, you could check the MAF output with the key on but not running. Then compare to the old one.
Old Dec 28, 2012 | 05:00 PM
LongBeachC4
I don't have a scanner but I will try the battery disco and see whet happens
Old Dec 28, 2012 | 05:16 PM
Muffin's Avatar
Muffin
MAF... Mass Air Flow, measures the weight of incoming air, has nothing to do with fuel. Burned or unburned fuel is detected by the O2 sensor.
Old Dec 28, 2012 | 05:27 PM
cumbercr's Avatar
cumbercr
I understand how fuel trim works. If he can't run long enough get out of open loop fuel trims don't matter.
If he can get a scanner on it, I can compare to the stock MAF readings on my 85. Even with the key off it should register a very slight amount of air flow.
Old Dec 28, 2012 | 05:29 PM
cumbercr's Avatar
cumbercr
Disconnecting the battery at this point won't help. I'll pull out my shop manual and see if there's any clues.
Old Dec 28, 2012 | 05:37 PM
cumbercr's Avatar
cumbercr
Try installing the old MAF and start the car. If it idles poorly, try disconnecting the MAF sensor. If the idle improves, the MAF is bad. If there's no change we may need to look elsewhere.
Make sure you didn't accidently disconnect a vacuum hose. There's some small ones near the MAF that go to the A.I.R valve.
Old Dec 28, 2012 | 06:59 PM
gerardvg's Avatar
gerardvg
Hopefully your maf will come good after a short drive, remember there is no need to clean a maf ever they have a burn of cycle of when you turn of your ignition. The 85 maf is an analogue one, the only other one i know that works is the 88 digital maf which i have in my 85.
Yes disconnect the battery, that is the first thing to do after any troubles. The ECM will try to compensate and change injector pulse widths and or idle speed, it can get itself in knots.
Check the maf numbers are the same (they are on the side or base of the maf). Then fit your new maf sensor start the engine and turn of the ignition, it will then do a burn off. Disconnect the battery after a minute for at least 30 secs and connect it. The car should start up idle at around 1200 rpm then slowly drop to 600 rpm, drive the car and it will relearn how to manage the engine a little hunting at idle will stabilize after driving with the normal stop light stops and normal driving.
If the idle screw has been adjusted you will need to do the base idle adjustment as per the service manual.
Old Dec 29, 2012 | 09:41 AM
WW7's Avatar
WW7
If you do find the maf sensor is your problem, here is what I found.....I went through 3 remanufactured maf sensors when mine went out a few years ago. Every one of them made my car run differently , but none of them made the car run right. One of them wouldn't even allow the car to start..My tuner and I finally came to the conclusion that after rebuilding them, none of the rebuilt maf sensors are anywhere near the original factory specs..Most remanufactured maf sensors are a waste of time, I would suggest trying to find a good used maf sensor that is still within factory specs , then your car will run properly..I finally went a different route going with a aftermarket maf sensor from Blowerworks that uses a sensor blade that's made for the 2005-2010 Ford Mustang and having my tuner adjust my chip to handle it...This was the best choice I have ever made on this car and have had no problems for the last 2 1/2 years...WW
To 85 MAF replacement
