Back to premium
Old Dec 29, 2012 | 12:49 PM
JackDidley's Avatar
JackDidley
Default Back to premium
After 3 years of using E85 in the 87 I switched back to premium. Reason is, its not available everywhere. Nearest pump is 6 miles away. Sometimes it cheaper to use. Sometimes premium is cheaper. Gas prices are crazy unpredictable. Anyway I like using it since its almost impossible to get spark knock with e85 in the tank. I could give the car a ton of spark advance. Good for gas mileage and bottom end torque. Not so good for traction. So its back to premium until the E85 is more available or a lot cheaper. Then its just a chip change and I can go back if I want.
Old Dec 29, 2012 | 01:36 PM
Rob31's Avatar
Rob31
I can get it ,Im north of Chicago . Is it the same from pump to pump ?
What kind of mods do you have ?
Old Dec 29, 2012 | 01:55 PM
JackDidley's Avatar
JackDidley
Its not the same pump to pump. Not enough difference that it matters. I have a ZZ4. Miniram and aftermarket 180 heads. Its clean burning, I have about 30k miles on my sparkplugs and last time I looked they were very clean. Oil doesnt turn black. I do like it but its currently not worth the inconvenience. I can get 93 premium 2 blocks from home.
Old Dec 29, 2012 | 02:15 PM
383vett's Avatar
383vett
I might be wrong, but I thought gas mileage is worse with E85.
Old Dec 29, 2012 | 02:38 PM
JackDidley's Avatar
JackDidley
You are correct. I would use maybe 25% more. Depending on the conditions and the tune. But sometimes its 70¢/gallon cheaper.
Old Dec 29, 2012 | 05:42 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
What did you have to modify in order to use E85 (replace fuel lines, injectors, etc)?
Old Dec 29, 2012 | 06:14 PM
JackDidley's Avatar
JackDidley
My 24# injectors were near maxing the duty cycle so I replaced them with bigger ones. I ran it several months with 24s though, no problem. I replaced the stock fuel lines under the hood with teflon core braided lines. Just didnt trust 23 year old stock ones. The stock rubber lines are still in use at the tank. The rest is in the tune.
Old Dec 29, 2012 | 06:15 PM
Aardwolf's Avatar
Aardwolf
I switched mine as well it's more octane for less cost! Have you thought of ordering a barrel? Or get some barrels and fill them up, use as needed. Just don't let them sit to long. I got a fuel tester from Summit it easily shows the E%.
Gary I just used injectors that flow more then did some computer tuning. A lot more fuel is used but it costs less. It's very clean!
Old Dec 29, 2012 | 06:17 PM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
E85 is only recommended for Flex fuel vehicles from 2012 and newer.
E15 - only recommended for 2001 and newer vehicles.
E85 (85% ethanol) was never recommended for our model years.
Now AAA is warning that using E15 will void manufacturer's warranty for cars OLDER than 2012 (does not apply for our years).
http://video.foxbusiness.com/v/2000862202001/
Looks like the govt. is 'poisoning the well' again.
Old Dec 29, 2012 | 06:29 PM
Aardwolf's Avatar
Aardwolf
That makes sense because it takes tuning to get it working right.
Old Dec 29, 2012 | 06:36 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Build an external "port" for microchips with dual, switchable slots. Flip the switch for whichever fuel you're running!
It could make millions!
Looking forward to seeing you on "Shark Tank"!
Old Dec 29, 2012 | 07:24 PM
JackDidley's Avatar
JackDidley
My chip is on a circuit board/zif adapter on the dash. Only takes seconds to change the tune.
Old Dec 29, 2012 | 07:38 PM
93 ragtop's Avatar
93 ragtop
Jack, as we speak, I have mine at a tuner now, hoping to be able to clean it up enough to pass emissions. I now have a 385 232-236 cam and 11.25 compression. Hope he can do it. Then I am going to switch back to the premium gas. He is burning 2 chips for me so I can switch back. BTW there is one e85 station in my area and its 20 or so miles away.
Old Dec 29, 2012 | 07:43 PM
JackDidley's Avatar
JackDidley
93 rag, we dont do smog here but it would be fun to see how the numbers look. My datalog numbers indicate a good burn. I am going to miss the sweet alky smell on cold mornings. I hate that smell with gas. Good luck at the smog check.
Old Dec 29, 2012 | 08:02 PM
93 ragtop's Avatar
93 ragtop
Jack, my tuner has a 5 gas? engine anlyizer and is going to use that to get it as clean as possible for the test. I think its at idle, 15mph and 25mph.
Old Dec 29, 2012 | 08:08 PM
JackDidley's Avatar
JackDidley
He should be able to do it. Be nice to see you do a thread with the results, if you can.
Old Dec 29, 2012 | 08:18 PM
93 ragtop's Avatar
93 ragtop
Yes, I plan too!!
To Back to premium
Old Dec 29, 2012 | 08:34 PM
ghlkal's Avatar
ghlkal
Andrew, I thought E85 would be corrosive on parts not designed for it. Did you do anything beside change injectors and a tune?
Old Dec 29, 2012 | 09:00 PM
Aardwolf's Avatar
Aardwolf
Alky is just bad if you binge on it! I haven't had any trouble, I did remember I do have an upgraded fuel pump. It's a Walbro 190 and before I had the 46 pound injectors I had some 32's that I ran very increased fuel pressure to get enough flow.
If you need help tuning let me know. Brian (bjankuski) also lives near to you and does tuning/dyno tunes.
Old Dec 29, 2012 | 10:22 PM
GREGGPENN's Avatar
GREGGPENN
Geez!!! How cool is that!?!?!?
