How much will these mods cost?
Old Jun 11, 2002 | 10:05 AM
Tigerhawk's Avatar
Tigerhawk
Default How much will these mods cost?
O.K., this is what I want to do this summer, any thoughts on how much I'm looking at. The car is a '94 LT1 w/55K miles. Also, any other mods needed or recommended w/new radiator and water pump? Thanks.
* High capacity aluminum radiator
* High flow electric water pump
* New Opti-spark
* 160* thermostat
* Plugs and wires
P.S.- What are my choices on the rad & water pump?
Old Jun 11, 2002 | 10:23 AM
vader86's Avatar
vader86
Default Re: How much will these mods cost? (LoFlyer)
Water pump-Meziere electric would be great, costs a couple hundred
radiator-Griffin, BeCool both cost somewhere around $200-300
If you had a vented opti it would be cheaper, you should upgrade to that instead of just a new one.
new plugs and wires will be something like $200 too.
Old Jun 11, 2002 | 05:10 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Default Re: How much will these mods cost? (vader86)
10 bucks for the thermostat and gasket
Old Jun 11, 2002 | 07:58 PM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
$1100-$1300 total if you do all the labor
Aren't the radiators $600-800?
[Modified by khornet, 3:59 PM 6/11/2002]
To How much will these mods cost?
