Doug Nash Cooling
Old Jan 2, 2013 | 11:14 PM
tgurnick's Avatar
tgurnick
Default Doug Nash Cooling
I'm not asking this question to be ignorant, but does the overdrive unit on the DN 4+3 NEED to have lines going to the radiator, or can it be bypassed to itself? I have not had any luck (yet) with the overdrive on mine functioning. I have the pan off of it to change the filter/fluid and things look great up in it, and at this point I'm cleaning up all of the electronics so the switch could be at fault for it not working, but I currently only care about the T10 gearbox. So, has anyone bypassed the radiator, not used it, and had any issues?
Old Jan 2, 2013 | 11:49 PM
Red88Vert's Avatar
Red88Vert
As a former owner of an 84 Z51, I can say DO NOT bypass the trans cooler. I ran my auto dry when a line blew on a long road trip (in the rain). I knew the auto quit, but the heavy rain washed the fluid off the undercarraige and I couldn't figure out what was wacked. When the tranny shop looked at it, my guy said "good thing you didnt run it manual only, as the drag would have worn out your syncros in a month".
Your money, but I would fix it. FYI, when my OD wouldn't light up, it was a bad ground .....needed a new ECU.
Old Jan 3, 2013 | 12:06 AM
tgurnick's Avatar
tgurnick
Yea, I plan to keep fluid in it. I was just curious as to whether the unit itself would have overheating problems when not in use and if that could effect just driving the car. What I'm getting from your reply is you had an incident running it without fluid yes?
Old Jan 3, 2013 | 12:24 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I can't imagine why you'd need a cooler; you're not running a tq converter . There would be some heat generated with a relief valve, but man...can't see it being that bad.
But to answer your question, I have not tried one w/o a cooler, so can't say for sure.
Old Jan 3, 2013 | 12:27 AM
Red88Vert's Avatar
Red88Vert
My tranny guy said that I couldn't run it for long in "coast" mode as it would were out the 4 speed. Others can validate if thats the truth or not. Is it not working?
Old Jan 3, 2013 | 12:37 AM
tgurnick's Avatar
tgurnick
Well, currently everything isn't working, but that's because I've been chasing an electrical short which has turned into a mild restoration... However, when I bought the car almost a year ago to date, when I was driving it the overdrive wouldn't engage, even when I pushed the switch on the console. I don't intend to drive with it engaged honestly. I just like the 4-speed and i'm not necessarily aiming for mpg's with this ride
Old Jan 3, 2013 | 12:40 AM
tgurnick's Avatar
tgurnick
Tom, your point makes sense. To me all the fluid does is lubricate and engage/disengage the parts. I don't think things would get hot with it disengaged and spinning, but, I don't know enough about these units. I know enough to realize the common failure parts but that's it
Old Jan 3, 2013 | 12:46 AM
Red88Vert's Avatar
Red88Vert
Got it. Hopefully there are some transmission pros around that can tell us for sure. I ran mine for about 3 months when the manual finally quit, but it was bone dry too in the AZ heat.
Old Jan 3, 2013 | 09:42 AM
tgurnick's Avatar
tgurnick
It sounds like you were very fortunate! Yea, if someone knows I'd be curious to hear. I feel like it'll be fine, but I don't know...
Old Jan 3, 2013 | 11:17 AM
glava2876's Avatar
glava2876
I have an 84 and I didn't see anthing regarding things that keep the OD from engaging. Obviously low fluid, but also low coolant temperature -it won't engage until about 180f or 185f.
Just wanted to be sure that you had this info also, because when I bought mine, it had a 160f thermostat and if it was cool at all, the temperature would not get high enough.
Old Jan 3, 2013 | 12:06 PM
tgurnick's Avatar
tgurnick
Gotcha. I didn't know that part of it, but i've had it up to temp plenty of times and nothing. Like I said though, I'm not too concerned with it working and using it, more of will it be alright to just run the cooling lines to themselves instead of to the radiator and back. When I swapped engines over the summer I cut the pre-bent lines pulling the engine and trans and was going to build my own back to the radiator, but it doesn't seem that there is really a need for it, considering I don't plan to use it. I could be wrong though, that's why I decided to ask here, haha
Old Jan 3, 2013 | 05:43 PM
c4cruiser's Avatar
c4cruiser
Reverse gear uses the direct clutch plates and packs in the OD unit. If they get too hot, you will most likely lose reverse. Also fluid pressures in the OD when it's working can hit up to 125psi. Fluid can get hot real quick at those pressures with no cooling.
As far as coolant temp levels that allow the OD to work, it's far different between the 84 and the 86-88 units. For the later cars, coolant temps only need to be around 122 degrees to allow the OD to work.
It really doesn't hurt anything to keep the coolant lines in place. Replacement steel lines can be fabricated easy enough, both for the proper bends and the flares and nuts. Just make sure you use the right type of steel tube that will handle the fluid pressures.
With the pan off, you can see the pressure switch and the OD solenoid. It's possible that either of these parts can be bad. The FSM has diagnostic procedures for testing the OD components, both electrical and mechanical.
Old Jan 3, 2013 | 09:28 PM
Red88Vert's Avatar
Red88Vert
The ECU sends a signal to the OD unit too (i think its a ground). My ECU went bad and quit sending the signal and my OD stopped coming on. ECUs are $85 now, so its an easy fix if thats the prob. Just saying .
To Doug Nash Cooling
